Request for long threaded pushrod
6 years 11 months ago #18771 by MikeSeale
Replied by MikeSeale on topic Request for long threaded pushrod
kevinross wrote: The metal control arm currently has a ball link fixed and changing it would require surgery
Presumably the ball link is removable from the ball? Could you drill the ball link to fit a non-threaded rod and then epoxy of CA the ball link to the metal rod - or is this anathema to you?
6 years 11 months ago #18772 by kevinross
Replied by kevinross on topic Request for long threaded pushrod
Time for a picture. Its just so easy to leave the ball link connected. drag out the piano wire (which will distort it) Then push a replacement in from the servo end and screw it in.
6 years 10 months ago - 6 years 10 months ago #18802 by kevinross
MikeSeale wrote: Sound like you have a similar setup to the all moving tail in my Phase 5.
hobbyking.com/en_us/threaded-ends-m2xl20mm-10pcs-set.html
You could then use a ball link or a standard clevis assuming you had enough clearance at the tail end to include the coupler as well as the clevis/ball
Following on Mikes suggestion, Ive solved the problem by silver brazing a wheel collet to a threaded adapter then re-tapped the m3 grub screw threads and filed matching indents on std piano wire.
Last edit: 6 years 10 months ago by Phil Ford.
Time to create page: 0.236 seconds
