Bucker Jungmeister repair
4 years 1 month ago #25026 by kevinross
Replied by kevinross on topic Bucker Jungmeister repair
After reassembly, used the crank protractor to verify the valve opening and closing was sensible (saito dont publish data) then used this RCxel ignition timing kit the verify the ignition timing.The LED extinguishes on the sensor trailing edge at 31deg BTDC.
4 years 1 month ago - 4 years 1 month ago #25027 by kevinross
Test run the engine today and for the first time in its life this inlet valve mechanism is getting lubrication so i hope it proves good in operation.
Q - why do i have to modify what is reputed to be one of the best Japanese engines to provide the basic requirement - lubrication.
Last edit: 4 years 1 month ago by kevinross.
4 years 1 month ago #25035 by 4Pedalsfly
Replied by 4Pedalsfly on topic Bucker Jungmeister repair
Hi Kevin - Perhaps an email to Mr Saito together with supporting pictures
may result in some interesting feedback ?
4 years 1 month ago #25037 by Phil Ford
Replied by Phil Ford on topic Bucker Jungmeister repair
Probably this 迷路 and don't darken our skies again.:lol:
Time to create page: 0.505 seconds
