DLE 55 Sheared Prop Bolts
17 Jul 2018 14:49 #17179 by Phil Ford
DLE 55 Sheared Prop Bolts was created by Phil Ford
Started up the engine for the first in ages with new prop fitted last time out. After starting I noticed the spinner was "wobbling". Removed it to find two out of four bolts have sheared flush with the drive hub. I need to get these devils out and no, I don't have small stud extractors. Options?
Will replace all bolts with "genuine" hi-tensile bolts next time round. :(
17 Jul 2018 15:18 #17180 by DavidTappin
Replied by DavidTappin on topic DLE 55 Sheared Prop Bolts
I have some extractors `Phil, don't know if they are small enough, what size are the sheared bolts?
17 Jul 2018 15:47 #17182 by JonTappin
Replied by JonTappin on topic DLE 55 Sheared Prop Bolts
Phil Ford wrote: Started up the engine for the first in ages with new prop fitted last time out. After starting I noticed the spinner was "wobbling". Removed it to find two out of four bolts have sheared flush with the drive hub. I need to get these devils out and no, I don't have small stud extractors. Options?
Hi Phil
I assume the new prop you fitted last time out was a wooden one? With wood props it's always worth checking bolt tightness if the engine hasn't been run for a while, as the hub can compress over time, which will loosen the bolts, this is even more likely to happen with a new prop. Then if the bolts are loose, they will eventually shear!
17 Jul 2018 16:10 - 17 Jul 2018 16:11 #17183 by Phil Ford
Replied by Phil Ford on topic DLE 55 Sheared Prop Bolts
Yes Jon :blush: :oops: Realised that when I was on my hands n knees in the grass, cussing. Have had the props become loose on the OS engines too but it's more obvious on them as they are just nuts. I should've rechecked the DLE bolts beforehand. :( Of course when I wound up the power metal shears given the chance.
Paying the price now with downtime.:(
Last edit: 17 Jul 2018 16:11 by Phil Ford.
17 Jul 2018 16:10 #17184 by Phil Ford
DavidTappin wrote: I have some extractors `Phil, don't know if they are small enough, what size are the sheared bolts?
They are 5mm David.
17 Jul 2018 22:25 #17189 by DavidTappin
OK Phil, I have a small enough extractor for that if you can't find anyone who lives a bit nearer. I'd be surprised if Peter W hasn't got one and you'll be with him tomorrow won't you? Kevin is another likely extractor owner a bit nearer to you.
18 Jul 2018 08:35 #17192 by Phil Ford
Thanks David, I will bear that in mind. Kevin, I believe is away on holiday.
I may try a tiny blob of epoxy on the bolt and a piece of 2mm control rod. hoping I can get at least the bolts proud of the prop driver to get a grip on. The bolts use to spin in easily enough just with fingers. Worth a try, last option drilling.
  • Simon O
18 Jul 2018 16:48 #17196 by Simon O
Replied by Simon O on topic DLE 55 Sheared Prop Bolts
What Sometimes Works Phil is drilling as big a hole as possible in the sheared bolt and epoxying a well fitting rod in the hole and then try winding it out.
18 Jul 2018 19:43 - 18 Jul 2018 19:46 #17199 by Phil Ford
Simon O wrote: What Sometimes Works Phil is drilling as big a hole as possible in the sheared bolt and epoxying a well fitting rod in the hole and then try winding it out.
Simon have moved your post from Shed Club? to DLE55 thread. I was getting confused momentarily. :lol:
That is my plan but without drilling first. Then if it don't work then the drill method. Then if that don't work then it's an engineering job.
Last edit: 18 Jul 2018 19:46 by Phil Ford.
18 Jul 2018 21:23 #17201 by JRI
Replied by JRI on topic DLE 55 Sheared Prop Bolts
Phil, I have some easyouts and small dremel drills, I should be able to out your sheared bolts if you can get the model to me!
Time to create page: 0.327 seconds
