Pilot RC Extra Convert from EP to IC
4 years 11 months ago #23551 by Phil Ford
Replied by Phil Ford on topic Pilot RC Extra Convert from EP to IC
Kevin Ross wrote: Well worth the extra work to put a servo on the choke Phil and as I know from J.J. that this engine carb arrangement is more difficult to link up than a DLE.
I have a sneaking suspicion that they designed the GP38 for the Pilot RC Laser seeing as they are promoting both in their videos.
4 years 11 months ago #23552 by Phil Ford
Ignition installed and fuel system all plumbed up. Job stopped now, waiting on a dry spell so I can get it outside and fit the wings. Then I will get some idea where the lipo packs will go to balance the plane. At present the fuselage is just balanced as it is right now.
Footnote: Great Power ignition modules use 6.6v to 8.4v but voltage must not fall below the 6.6 v when in use. Made for Lipo packs then.;)
4 years 11 months ago #23562 by Phil Ford
I was allowed to bring the Extra into the kitchen as the weather is very unsettled and it is "dry - no fuelled". I really wanted know where the batteries were deemed to go to get the C of G right without having to add ballast. With the wings on and the receiver pack on the CG as it was before it was tail heavy. Now place the ignition pack alongside the tank and it just balances. Prop and Spinner weigh 160 gms so stick them on and the nose just drops a little. So, we are close but first flight will tell.
4 years 11 months ago - 4 years 11 months ago #23565 by Phil Ford
Today, Monday stayed dry so with much anticipation took the extra outside on the grass. Fuel it up and give a whirl. Flicked and flicked and nothing. Fuel in the line so much be not pumping. Squirt some fuel in the carb. Bang and it fired and run till fumes ran out. Did this twice more. Persevere and it started and ran happily at a fast idle. I let tit run for a few minutes and then shut down. After cooling off period got it running again and now increase throttle higher and higher. Runs real nice. I have not touched the needle settings yet but it cannot be far off judging by the way it ran. Spitting with rain now.
Back in doors wondering what to do about the receiver and power switch. The mechanical switch has been fine whilst the plane was electric but now we have vibration to contend with. Lucky for me I had a brand new JR RD22 Power Box with three Sats. Replaced the AR9000 with the RD22. Also added twin lipo packs on the CG line. Bound it and everything working fine. I didn't like the JR fail-safe switch so I modded a DualSky fail-safe switch also known as Pin and Flag. This version lights up when the system is on. I like these because it reminds me to switch off the power after flights.
On reflection, I think that if I had not had the RD22 salted away I would have used Open TX with Frsky Pro receivers and a RB20 Power Bus.
Waiting on the weather now for it's flight so in the meantime back to repairing the Zagi. It's likely to get more use judging by the future windy forecasts.
Last edit: 4 years 11 months ago by Phil Ford.
The following user(s) said Thank You: 4Pedalsfly, kevinross, Brian
4 years 11 months ago #23566 by ruggerbloke
Replied by ruggerbloke on topic Pilot RC Extra Convert from EP to IC
Neat install Phil. Looking forward to the second maiden!
4 years 11 months ago #23567 by Phil Ford
Denis Murphy wrote: Neat install Phil. Looking forward to the second maiden!
So am I Denis. ;)
