Electric pump
9 years 11 months ago #6505 by JonTappin
Replied by JonTappin on topic Electric pump
flyingpete wrote:
JonTappin wrote: By the way, its about time you changed your avatar pic, that's my model!! :)
It's done!
Replaced by a silhouette :( I was expecting a Panther!
9 years 11 months ago #6507 by
Replied by on topic Electric pump
i have never managed to make a (glow fuel) pump last for very long so my money would be on the hobbyking one.
9 years 11 months ago #6517 by
Could you use positive air pressure in the fuel bottle to drive the fuel into the tank. Likewise pressurise the fuel tank to empty it. (this would also highlight any leaks in the clunk to tank bulkhead tubing.)
Air pressure from standard tyre inflator.
9 years 11 months ago #6524 by JRI
Replied by JRI on topic Electric pump
flyingpete wrote:
JRI wrote: www.hobbyking.co.uk/hobbyking/store/__17..._Pump_Nitro_Gas.html
£4 1/2 smakeroonees, takes a while but gets there in the end. Gives me time to pump up the air bottles and do other checks while its filling!
How long will it last?I could always buy a couple
It's just a simple geared pump with a brushed cheap dc motor. I guess it will last as long as the brushes. I have 4 in-line fuel filters of varying mesh which probably slows it down a bit - then again it isn't powerful enough to blow off any connectors.
9 years 11 months ago #6526 by
I like the idea of the air pressure especially as you have a compressor for the retracts anyway.
only concern is what pressure (if any) are those jerrycans rated for and what is their mode of failure? will it just spring a leak or will it tear and fail suddenly with a large amount of highly flammable liquid floating around?
9 years 11 months ago - 9 years 11 months ago #6530 by
This was not my original idea - My son used it for filling wing tanks with petrol on his FoxKit plane. (Full size). With the jerrycan on the ground, he generated a 7ft head with no ill effect.
The pump was a mains driven air pump intended for a Koi fish pond.
Just Googled the idea - Search for Polarn Pump.
Last edit: 9 years 11 months ago by .
Time to create page: 0.247 seconds
