This could be fun
7 years 11 months ago #14331 by Chris73
Replied by Chris73 on topic This could be fun
MikeSeale wrote: Congrats on completing the build
Now that it is done what are your views regarding alternative components? Specifically:
1.would it be easy to use a different motor or is the Hacker a tight fit?
2.would it be possible to fit a fatter 3 cell battery or is the thinner 2 cell tight already?
3.is there room for a slightly bigger ESC?
4.would it be a pain trying to fit servos that are slightly different shapes or sizes?
Space is really tight for all of the components
1) It would be possible to use another motor but it would have to be the exact same size
2) I have some 2S 650mah batteries and you would not get anything any bigger in there
3) The recommended ESC only just fits
4) Fitting slightly different shape or size servos would be a real headache
I will bring it to Cashmoor on Saturday so people can make their own decisions on using different components, personally I would stick with the recommended parts
The following user(s) said Thank You: MikeSeale, Brian
7 years 11 months ago #14336 by Brian
Thanks for the build info Chris. I'm going to use a "Hacker equivalent" from 4Max, everything else is the same spec. The front end looks very busy, apart from the vented spinner, is there any provision for cooling?
7 years 11 months ago #14337 by Chris73
Hi Brian, there is no provision for cooling
I am going to use some sticky pads and try and tidy things up a little in the front, but there is so little room i think it just "is what it is"
7 years 11 months ago - 7 years 11 months ago #14338 by Brian
I looked at the kit again. Not a lot for the money, especially when the postage is added.
7 years 11 months ago #14340 by kevinross
Due to lack of support in a group purchase and the apparent difficulties in using alternative more cost effective hardware, i'm putting my plans on hold.
7 years 11 months ago #14362 by Brian
Can a Gurke be built from the plan supplied in the kit? Probably a daft question!. If the model could be built without using the laser cut parts, would anyone lend me the plan so that I could copy it ?
Time to create page: 1.780 seconds
