Mini LecRoo
  • 4Pedalsfly
14 Feb 2018 14:17 #15771 by 4Pedalsfly
Mini LecRoo was created by 4Pedalsfly
This model appeared in RC "Model World" as a free plan feature and being of balsa & ply construction
appealed to me. With the onset of the colder weather I decided it was time to get back into some traditional building
using up some of my stock of 1/4 in balsa sheet. Why did I buy that years ago ?
It is a simple build and when finished should provide some exciting delta flying, power to rate ratio should be in the region
of 200 Watts per pound. Being a tractor delta it can be easily hand launced without any danger of damaged fingers.
If anyone else is interested in building one I can get a 2 page set of A1 sized plans printed for £4.40 at Xercad in Ferndown and
also supply an electronic copy of build review.
Pics show model start of build thread.
Colin.A
  • 4Pedalsfly
14 Feb 2018 14:32 #15772 by 4Pedalsfly
Replied by 4Pedalsfly on topic Mini LecRoo
More pictures - I used "Deluxe Materials" Aliphatic Resin for gluing the 1/4 in balsa sheets together, these being
pinned and weighted and left overnight to fully dry.
This Deluxe Materials glue is my preferred one for balsa to balsa joints.
  • 4Pedalsfly
02 Mar 2018 12:38 #15840 by 4Pedalsfly
Progress continues at a slow pace.
See 2 pics attached.
02 Mar 2018 12:54 #15843 by MikeSeale
Replied by MikeSeale on topic Mini LecRoo
4Pedalsfly wrote: Progress continues at a slow pace.
Maybe slow, but looking at the plan I'd say you've nearly finished now that you have three parts made.
02 Mar 2018 16:36 #15846 by Phil Ford
Replied by Phil Ford on topic Mini LecRoo
:lol: Just needs a little Lipo and ready to go?
  • 4Pedalsfly
02 Apr 2018 10:46 #16227 by 4Pedalsfly
Fuselage sides & formers fabricated - fuselage assembly begins.
1 pic attached.
  • 4Pedalsfly
01 May 2018 10:48 #16462 by 4Pedalsfly
Progress continues at a sedate pace.
Elevons carved, fuselage glued to wing and control system test fitted.
Pics attached.
Now onto cowl & fuselage canopy.
01 May 2018 10:53 #16463 by DavidTappin
Replied by DavidTappin on topic Mini LecRoo
Looking good Colin most impressive, also I'm greatly impressed by your veritable battery of batteries!
  • 4Pedalsfly
01 May 2018 23:06 #16473 by 4Pedalsfly
DavidTappin wrote: Looking good Colin most impressive, also I'm greatly impressed by your veritable battery of batteries!
Yes David they make great weights, supplied f.o.c by a local company who service alarm systems.
  • 4Pedalsfly
21 Nov 2018 17:07 #18313 by 4Pedalsfly
Here I am updating you on the Mini Lec Roo, it's been over 7 months since the last post and the bits had been gathering
dust in the workshop,so time to get the project moving again.
Canopy and cowl completed, airframe needs a sanding and filling as required ready for covering.
Glass fibre reinforced tape will be applied over parts of the wing to increase stiffness followed by covering
the whole model in TopFlite " Monokote" plastic film.
See 9 pics that follow.
Next posting will be of the finished model, hopefully in less than 7 months !!
