3D Printing
02 Feb 2020 15:54 #21570 by Brian
Indeed the Joker bits are assembling into something that looks remarkably like the photo in the maker's advert. Yesterday the fuselage parts were glued, the carbon reinforcing tube slid in without any fuss. The tail plane and elevators went together in the same manner. There was a small snag when gluing the tail plane to the spar "stubs" on the fuselage, I'd spread a little too much cyano on the stub, when the tail plane was slid into place, the glue ran over my thumb. I never felt a thing. It took quite a while with debonder and a small paint brush before I could put the model down. Now I wonder if the CAA will accept my thumbprint instead of a printed code number?
I don't know about making it ballistic Phil, I prefer the slower option, at least it should take longer to crash if it flies a bit slower. Good to hear that the joiners worked out.
I hope no offence has been caused by the photo of my newly unglued thumb.
03 Feb 2020 09:54 #21571 by Phil Ford
Brian wrote: I hope no offence has been caused by the photo of my newly unglued thumb.
Glad you mentioned it was your thumb. Initially I thought it was a ............
03 Feb 2020 18:10 #21578 by Brian
Most encouraging Phil, and most kind of you to suggest that it might have been a less robust part of my anatomy, however I must point out that I'm Eighty seven and some months and my thumb is much larger than ......
04 Feb 2020 11:20 #21581 by Brian
The Joker's wings have been fitted. Small amounts of material had to be filed off the rear of the wing joint, this enabled the fixing screws at the front of the wing joint to line up with the two 4mm tapped holes in the fuselage. So far the fit of all the parts has been very good. No photos today as windy weather makes outdoor model photography a bit perilous. Now I know there won't be a problem with fitting the wing to the fuselage, I'll go ahead with the assembly of the flaps and ailerons, fit the servos, and I'm almost finished (I think). The brushless motor fits nicely on to the pre-moulded front bulkhead, don't see any problem there.Thinking ahead and the possibility of warm sunny days (now there's a happy thought), I wonder how I'm going to be able to keep a 1.7M model in the shade without taking it apart?
04 Feb 2020 11:42 #21582 by Phil Ford
Brian wrote: I wonder how I'm going to be able to keep a 1.7M model in the shade without taking it apart?
No problem. Give it to me. :lol:
04 Feb 2020 12:16 #21584 by Brian
Can't give it to you Phil, you said you had "too many models", you cast a long shadow, perhaps you'd stand by the model while its on the ground, for a very small fee of course.
04 Feb 2020 19:04 #21595 by Brian
Finally got down to the shed today, spent a while hunting out suitable screws to hold the motor. The designers didn't make assembling the motor to the model an easy task. The holes for the motor mounting screws are under 3mm, so the screws had to be "screwed" in. It took me quite a while to figure out a way to get things lined up. Finally it all came together and at last the motor was fixed. When the prop hub/spinner was attached to the motor shaft, I could see that down and side thrust had been built in. That's good, 'cos dismantling the motor and adding packing washers wouldn't be a fun thing to do. So far the servos are centred and fitted, the motor is in and plugged in to the ESC, No blades will be fitted until the motor runs the right way! HobbyKing have refunded the cost of the motor they didn't have in stock, and I've saved a decent sum by getting four LiPos from them, so it can't be too bad.
04 Feb 2020 20:38 #21597 by DaveBright
Good stuff Brian! I will collect those specially commissioned parts soon I promise!
05 Feb 2020 19:01 #21602 by Brian
Hi Dave, I'll bring the thingys to the meeting on Friday. See you then.
B.
07 Feb 2020 12:26 #21623 by Brian
Today I found the perfect excuse to not fly the Joker. A new piece to be left behind. The absence of the piece only being discovered after assembling the model on the field and wondering "What the ***!!!***" did I do with the darned thing?
The attached photos will give you some idea of what the missing part is, and does.
The ultimate safety device for an electric model, a cheap 'n cheerful Deans plug in a 3D printed holder.
The plug isn't shown 'cos HK haven't delivered the connectors I ordered............yet. I'm hoping I don't get a "On back order" message.
Time to create page: 0.492 seconds
