Angel dust
10 years 2 weeks ago #5765 by MikeSeale
Replied by MikeSeale on topic Angel dust
AlanF wrote: but, how are you going to make it sound like a real aeroplane ;)
That's easy, I can just switch off the motor to make it sound like a REAL aeroplane
10 years 2 weeks ago #5767 by flyingpete
Replied by flyingpete on topic Angel dust
Superb job mike B)
10 years 2 weeks ago #5768 by AlanF
Replied by AlanF on topic Angel dust
:lol:
10 years 2 weeks ago #5769 by
Replied by on topic Angel dust
Fantastic Mike... do you have a date in mind for when you're going to take it up to the field?
By the way the Aurora, might have one stumbling block, it originally came with a fiberglass 'Chin Cowl' that goes from just behind the spinner to the trailing edge of the wing, however it along with a canopy can be got from the states... not that I've been researching it at all... $20 for the Canopy, $40 for the Chin Cowl, no idea on postage.
10 years 2 weeks ago #5770 by MikeSeale
I'm hoping to fly it on Saturday, Chris. But I did have a little set back today and the maiden will have to wait if I can't program the model tomorrow evening.
The problem I had was when I put everything inside to check the CG I found that it was nose heavy, even with everything as far back as possible. A bit of head-scratching later and I decided the best solution was to relocate the rudder and elevator servos a little further back. Not only did this mean re-doing the rudder and elevator pushrods, but while I was hammering away I managed to knock the canopy off. This did mean I could spend the rest of the day not worrying about knocking it again, but I have had to re-glue it and it feels a little like I'm back where I was last night.
However, everything else is secured in the right place. And the main flight battery now sits right on the CG. This is good news because I will be able to try heavier and lighter batteries without it affecting the CG. The weight, ready to fly, is 7lb exactly with the heavier 40C 4000mAh battery. I might maiden it with the 20C 3000mAh battery which means it will fly at 6lb 10oz.
And another bit of good news...when I was planning the build I thought long and hard about a top hatch to swap the flight battery without removing the wing. In the end I decided not to bother because I felt the strength of the fuselage would be compromised too much. What a good job I didn't bother, because I would have made the canopy area removable, because my motor and battery weigh about the same as a 60 and a tank of fuel. If I had made the canopy hatch I would have access to a big empty space and still have to take the wing off to swap the battery!!!
10 years 2 weeks ago #5771 by MikeSeale
Chris001 wrote: no idea on postage.
USPS charged $16 for my canopy. That's why I bought two, because I could't face spending twice as much on postage as the item inside.
Time to create page: 0.302 seconds
