Royal Kit for Bleriot Mk XI
  • Phil-C
25 Aug 2015 19:18 - 25 Aug 2015 19:27 #5613 by Phil-C
Royal Kit for Bleriot Mk XI was created by Phil-C
After spending weeks wondering whether to build this or not, and after receiving a good thread link from Colin A this morning (thanks Colin) I decided to go ahead. This is a die-cut kit, and the bits don't come out as well as laser cut ones. The horizontal stabiliser is weakly attached and fully flying. Both flying surfaces are highly under-cambered. The undercarriage is a long way from scale. So, I shall build it to the plan and see how it works out.
I will be sparing with posts, commenting on each component as it is finished. Here is the first part of the build.
The stabiliser requires some work on the TE before pinning it all down, then mucho packing to allow for the under-camber. The ribs are about 5/16" deep, all the way across the chord, so I had to pack up the main spar to get it all to line up. I shall use Aliphatic glue throughout, with Epoxy for highly stressed bits. I intend to cover it with some light weight nylon that has been in my box for some time, stained in places so that will add character... Two coats of thinned dope to finish. Electric drive, yet to sort out. The plan does not call for wing warping, but let's see.
Last edit: 25 Aug 2015 19:27 by Phil-C.
26 Aug 2015 12:47 #5629 by 4Pedalsfly
Replied by 4Pedalsfly on topic Royal Kit for Bleriot Mk XI
Phil - Great to see that you decided to go ahead with the build.
  • Phil-C
28 Aug 2015 08:50 - 28 Aug 2015 08:51 #5647 by Phil-C
Replied by Phil-C on topic Royal Kit for Bleriot Mk XI
Here is the nearly finished tailplane, with the actuator stood in place: it gets bound and epoxied later. Also note the undercamber and thinness of the aerofoil. I might add capping strips to the underside, from 1/64" ply.
Last edit: 28 Aug 2015 08:51 by Phil-C.
28 Aug 2015 12:47 #5650 by MikeSeale
Replied by MikeSeale on topic Royal Kit for Bleriot Mk XI
Looking good, Phil. Be careful adding weight at the back of a model with such a short nose. I think the covering will add all the strength needed without capping.
  • Phil-C
28 Aug 2015 17:57 #5654 by Phil-C
I shall be taking some weight out of the all steering rudder. The kit bit is solid hard 3/32" balsa with ribs. Also, replacing the 2/1/2" tail wheel with a tail skid (which some of the 900 plus Bleriot XIs had).
  • Phil-C
30 Aug 2015 19:46 - 30 Aug 2015 19:52 #5675 by Phil-C
The flying fin/rudder. I took some balsa out of the rear panel and used it to stiffen the structure vertically. The hinges go in the thick tapered bit, and the bit sticking up has to be stiff. As designed, it was just a 1/8" balsa plate, with the two lateral aerofoil ribs each side. I'm using inches because this American Kit, made in Japan, is in inches. I guess the original would have been in mm, as it was French!
The plan shows hinges as little bits of flat plastic. I have a few Robarts which will be stronger. Holding the structure fixed by the tapered bit, it is actually more robust than I expected.
Last edit: 30 Aug 2015 19:52 by Phil-C.
30 Aug 2015 21:08 #5680 by 4Pedalsfly
Looking good Phil - a couple of round holes in R2 would not go amiss.
Inch holes not funny metric ones.
Coli.A
  • tommy
30 Aug 2015 21:28 #5682 by tommy
Replied by tommy on topic Royal Kit for Bleriot Mk XI
I'm liking these build threads, great variety of aircraft being built and great to see both kits and plan builds happening. So far so good Phil, I don't envy you the covering job with the undercamber !!!
  • Phil-C
31 Aug 2015 19:02 #5696 by Phil-C
Fin Finished. Imperial holes, Colin. Didn't save much, as can be seen, but it's stronger.
  • Phil-C
31 Aug 2015 19:09 - 31 Aug 2015 19:12 #5698 by Phil-C
Spent today getting ready to build the wings. Sanded the ribs to make them the same shape, also cut out various gussets and made ready for the wing joiners.
There is only one wing spar. Looks lonely. Do I add more? Now is the time.
Last edit: 31 Aug 2015 19:12 by Phil-C.
Time to create page: 0.390 seconds
