FrSKY Taranis X9E
11 Feb 2018 09:39 - 11 Feb 2018 09:39 #15705 by Brian
FrSKY Taranis X9E was created by Brian
If anyone with a Taranis X9E wants to convert the gimbals to the M9 Hall Effect type, I have a pair of adapter rings to enable the M9 gimbal to fit the X9E case. Let me know and I'll get them to you.They are FOC as I no longer need them.
Last edit: 11 Feb 2018 09:39 by Brian.
11 Feb 2018 09:43 #15706 by MikeSeale
Replied by MikeSeale on topic FrSKY Taranis X9E
I'm sure that either Chris or I will take them off your hands. Chris already has M9 gimbals installed but did not use adapter plates. I'll switch to M9 gimbals at some time in the future.
11 Feb 2018 09:50 #15708 by Brian
Replied by Brian on topic FrSKY Taranis X9E
OK Mike, they're yours.
11 Feb 2018 21:41 #15743 by MikeSeale
Thank you.
18 Mar 2018 23:08 #16073 by Chris001
Replied by Chris001 on topic FrSKY Taranis X9E
Brian wrote: ...I have a pair of adapter rings to enable the M9 gimbal to fit the X9E case...
Hi Brian, could you let me know where you got the adaptor rings from? Many thanks, Chris
19 Mar 2018 07:51 #16074 by Brian
'Morning Chris, the item is made by RC Studio in Czechoslovakia. their web page is www.rcstudio.cz . Its only now that I realised I should have put out a notice about buying the spacers. Would have saved lots of postage.
19 Mar 2018 08:00 #16075 by Chris001
Thanks Brian,
That was where I was going to order from too, I'd hoped you'd found some where closer, I could not justify 15,76€ postage for a 0.79€ item :pinch:
I put the gimbals in at the end of November without the adaptor rings, and the looks don't bother me, but if they come up at a reasonable price it would be nice to finish off the job.
Thanks again, Chris
19 Mar 2018 08:18 #16076 by Brian
Hi Chris, they must've hiked up their postage rates! I wonder if someone in the Club could print some rings? I can't remember who took over Frank's 3D printer.
The spacer rings from RC Studio are 3D printed. The rings are flanged to stop them falling out, and all they do is fill the gap. I wonder if 1/8"(3mm) tape could be wound round the location "boss" on the gimbal, painted black before assembly. Fiddly but fun!
19 Mar 2018 08:30 #16077 by Chris001
You're right Brian, I've just tried again it's now 15,43€ P&P :( I'd be curious to know how you got a different postage rate, you must have contacts and persuasion on your side ;)
Anyway, it's only an aesthetic thing so I'm happy to leave it as is.
19 Mar 2018 09:54 #16078 by Brian
I'll check out what I paid for the spacers Chris. In the meantime, don't eat biscuits while you're flying with the x9E, don't want crumbs in the gaps.
Time to create page: 0.344 seconds
