- Thank you received: 0
Topic Author
Topic Author
Topic Author
If you can't measure resistance I'm sure several of us will be able to help you out.Wingman1962 wrote: I'm not sure if I can measure resistance with my charger I will have a look when I get home.
It would be unusual for it not be be ok. When you advance the throttle you should notice that it reaches full power a few notches before full stick movement. If it's still getting louder all the way to the top you might find that you're end points are not giving you full power.Wingman1962 wrote: I have sett the throttle using the guide for the hobbywing esc I can only assume that it's right.
Topic Author
Topic Author
