Grub screw removal
  • ruggerbloke
  • Junior Member
  • Junior Member
4 years 9 months ago #23898 by ruggerbloke
Replied by ruggerbloke on topic Grub screw removal
Thanks again Kevin. I'll have another look this morning in the cold light of day and consider all options. This forum is invaluable for help from so many experienced modellers/engineers. Thank you all.
4 years 9 months ago #23904 by Chris73
Replied by Chris73 on topic Grub screw removal
A safer option than a blow torch is to use a soldering iron, just hold the tip of the iron on the grub screw, that way you are only heating the bit that you want heat on
4 years 9 months ago #23905 by DaveBright
Replied by DaveBright on topic Grub screw removal
Chris Hughes wrote: A safer option than a blow torch is to use a soldering iron, just hold the tip of the iron on the grub screw, that way you are only heating the bit that you want heat on
This is how I soften loctite too.... blue and occasionally the red stuff if used in error :-)
  • ruggerbloke
  • Junior Member
  • Junior Member
4 years 9 months ago #23906 by ruggerbloke
Thanks to everyone that took the time to reply. It's nice to know that everyone, regardless of experience has come up against this type of problem in the past. Cheers all.
4 years 9 months ago #23907 by JRI
Replied by JRI on topic Grub screw removal
A popular method seems to be to use a tungsten carbide drill into the remaining head of the grub screw, then gently hammer in a torx screwdriver bit, apply heat to the bit using a soldering iron, then attach the screwdriver body and it should remove easily.
  • ruggerbloke
  • Junior Member
  • Junior Member
4 years 9 months ago #23908 by ruggerbloke
Thanks all. I have now managed to find a front fixing prop driver that fits. All tested and the propshaft luckily is not bent to no need to remove grubscrews now. Result! Thanks for all your input.
Time to create page: 0.585 seconds
