Christmas Curare EP
9 years 9 months ago #7630 by JonTappin
PhilF51 wrote:
Jon, you had 16 clicks of right rudder dialled in on the TX. So, while indoors I removed the cowl and checked the firewall position and motor adaptor. There is no right thrust built in. Do you think a degree or so of right thrust would do the trick to centre rudder. Never heard you mention anything before regarding your IC Curare.
You will definitely need right side thrust if you have none, I thought it was already built into the front bulkhead though?
Can't really remember what I did with your rudder trim, but if it needs right trim then increase the side thrust. 2 deg would be a good starting point.
Time to create page: 0.986 seconds
