Sebart Mythos Throws
13 Jul 2016 20:59 #9268 by Chris001
Replied by Chris001 on topic Sebart Mythos Throws
Hi Phil,
I had an issue with my servos and they were sent back on 15th or April, I got them back today, 13th July! :woohoo: Otherwise the Mythos would have been finished before the Atlas.
Thanks for looking at your Angel, alas different servos... If I've not sourced an arm by the weekend, I might make one up out of fiberglass and glue it to an existing servo arm.
13 Jul 2016 21:09 - 13 Jul 2016 21:11 #9269 by JonTappin
Replied by JonTappin on topic Sebart Mythos Throws
Try this one Chris, Secraft 2.5in JR, according to the drawing the middle holes are 50.8mm apart
www.hobbyplastic.co.uk/index.php?main_pa..._75&products_id=7572
www.macgregor.co.uk/secraft/SEC019.htm
Last edit: 13 Jul 2016 21:11 by JonTappin.
14 Jul 2016 07:40 #9270 by Chris001
Thanks Jon, that looks like it will do.
14 Jul 2016 13:36 #9271 by 4Pedalsfly
Replied by 4Pedalsfly on topic Sebart Mythos Throws
Hi Guys - Am I missing something here, why not drill the rudder arm out at 40mm to match the servo arm ?
Is it perhaps to do with precise rudder movement ?
14 Jul 2016 13:47 #9272 by Chris001
Alas Colin, I've epoxied in the horns into the rudder which is glued onto the fuselage so any drilling would be fraught with danger now.
14 Jul 2016 14:42 - 14 Jul 2016 14:43 #9273 by JRI
Replied by JRI on topic Sebart Mythos Throws
I have dead-center tool that would safely do the drilling job Chris .. also a set of pin-vices for small drills.
Last edit: 14 Jul 2016 14:43 by JRI.
14 Jul 2016 19:11 #9281 by Chris001
Thanks John,
I didn't see your post until after I'd dived off in a different direction. Being a total cheapskate, I decided to go the DIY route
17 Jul 2016 16:43 #9314 by Chris001
With servos with metal output shafts, do you loctite the arm retaining screw, or is the grippy washer enough?
By the what Jon & Chris, the jig for enlarging the hole in the tail worked well, 4.5 hours to design it, build it and test it. :evil:
Okay, I used masking tape, a steel ruler and a scalpel, but the jig would have been more precise!
17 Jul 2016 17:32 - 17 Jul 2016 17:33 #9317 by Phil Ford
Replied by Phil Ford on topic Sebart Mythos Throws
Chris - Do not loctite the locating screw. Read the info on metal gear servos! Just make sure you have the star washer underneath the screw head and tighten. If you have to return the servo due to failure they will throw it back at you when they spot the blue.
Last edit: 17 Jul 2016 17:33 by Phil Ford.
17 Jul 2016 18:10 - 17 Jul 2016 18:11 #9320 by Chris73
Replied by Chris73 on topic Sebart Mythos Throws
Chris001 wrote: With servos with metal output shafts, do you loctite the arm retaining screw, or is the grippy washer enough?
I always Loctite them (Just vibration proof, not permanent loctite)
I dont care what the instructions say, on a petrol model the screw wouldn't be in there for more than 5 minutes without Loctite, might not be so bad on an electric model, but personally i wouldn't risk it. Lose a servo arm there is a very good possibility that you could lose the model!!
Last edit: 17 Jul 2016 18:11 by Chris73. Reason: Can't spell
Time to create page: 0.402 seconds
