Sebart Mythos Throws
17 Jul 2016 18:12 #9321 by Chris73
Replied by Chris73 on topic Sebart Mythos Throws
By the way, where were you Chris??
I was the only one at the field today and it was perfect flying weather B)
17 Jul 2016 20:14 #9324 by Chris001
Replied by Chris001 on topic Sebart Mythos Throws
Chris,
After the barrage of insults and cutting remarks from certain people yesterday about the lack of progress with my Mythos I felt compelled to forgo the flying and enjoyment of your good company today, and see if I could make some small but noticeable progress with the Mythos... And progress has been made, not much grant you, but yep, things have moved forward... sort of. In between my procrastination driven innovative and studious building style, going forward, I flew my little helicopter, I think I could be tempted over to the helicopter world. :evil:
Back to servo arm screws, we have one vote for loctite and one no loctite vote... Phil I don't think JR servos come with instructions, just specs. Phil you said read the info on metal gear servos, is that on this site, or an external link?
17 Jul 2016 20:20 #9325 by Chris73
OK, no more cutting remarks from me
Now stop p***ing around and get the bloody thing finished!!!!
17 Jul 2016 21:22 #9329 by JonTappin
Replied by JonTappin on topic Sebart Mythos Throws
Chris
I have never previously used threadlock on output screws and relied on the star washer. However I recently had an arm come off on the Sukhoi because the screw came out, luckily it was on one aileron and each has 2 servos, but on a single servo surface it could have been a big problem. I will now be using threadlock on metal output shafts. To me, risking a warranty issue is less of a concern then risking losing a model.
Oh and by the way, get on with it!!
17 Jul 2016 21:26 #9331 by Chris73
He has probably got to make a jig now to apply the Loctite !!!!
17 Jul 2016 21:26 #9332 by DaveBright
Replied by DaveBright on topic Sebart Mythos Throws
I had a metal JR arm(star washer with centre bolt and clamp bolt) pop off an aileron servo in the early flights of my Sbach. I added a little blue loctite to everything after that and no issue in the subsequent 4 years.
17 Jul 2016 21:27 #9333 by DaveBright
Chris73 wrote: He has probably got to make a jig now to apply the Loctite !!!!
17 Jul 2016 21:59 - 17 Jul 2016 22:05 #9334 by JRI
Replied by JRI on topic Sebart Mythos Throws
Tales of servo woe might be indicative of lack of maintenance (I plead guilty too). Star washers flatten and aluminium and plastic squashes so it really should be a compulsory check that all screws are tight at the beginning of every flying session. Loctite (blue) may only mask the problem as a loose arm will soon strip its splines even if the screw doesn't come loose any more.
Last edit: 17 Jul 2016 22:05 by JRI.
18 Jul 2016 08:53 #9335 by Phil Ford
Replied by Phil Ford on topic Sebart Mythos Throws
Not wishing to hijack an informative thread about Mythos Throws ;) I can own up to a tiny drop of blue on the Beasts rudder servo after the ally arm fell off. Never had an issue with hd plastic arms though, probably a tighter fit on the splines.
18 Jul 2016 11:37 #9337 by Chris73
PhilF51 wrote: Chris - Do not loctite the locating screw. Read the info on metal gear servos! Just make sure you have the star washer underneath the screw head and tighten. If you have to return the servo due to failure they will throw it back at you when they spot the blue.
Make up your mind, you were the one that said not to use any :silly:
