  • simonbloke
16 Feb 2017 18:09 #11941 by simonbloke
Replied by simonbloke on topic New Model, first adventure into petrol
Hi.
Happy Bunny ... :P :)
It looks good and the engine is fab.
Got a bit of fettling to do as not quite ready to fly, got some dangly bits a nd a box of wires the need connecting to something.
Bit of time needed to get to understand thing, so i think I will be asking loads of questions !!
Couple of pics
16 Feb 2017 18:29 #11942 by Phil Ford
Replied by Phil Ford on topic New Model, first adventure into petrol
Good buy Simon. ;) Go through Franks electrical wiring though, he had different ideas to almost everyone else. I found that out on his Mustang 40 I grabbed a while ago. :lol:
The following user(s) said Thank You: simonbloke
  • simonbloke
16 Feb 2017 18:34 #11943 by simonbloke
Hi.
Will do alsorts of things have come with it, and am somewhat confused !!
Been chattting to Kevin and he has given me loads of advise
Be a while before she flys but looking forward to the building and setting up
Simon
16 Feb 2017 18:55 #11946 by Chris73
Replied by Chris73 on topic New Model, first adventure into petrol
Just post away if you need any help Simon, I am sure between us we can help you out :)
  • simonbloke
16 Feb 2017 19:57 #11948 by simonbloke
Hi
First Question; :whistle:
Anyone know where i might be able to get some build instructions for this x-tech Yak....
Ta
Simon
17 Feb 2017 09:04 #11952 by Phil Ford
simonbloke wrote: Anyone know where i might be able to get some build instructions for this x-tech Yak.
Is this it? X-Tech Yak 30 -35cc.
17 Feb 2017 09:28 #11954 by Chris73
No its not, this is for the new composite models that X-Tech now make
Simon's is a completely different model
17 Feb 2017 09:33 #11955 by Chris73
Very unlikely that you will find any, but it should go together like any other model you have
If you get stuck, post a pic on here and I am sure someone will have the answer
  • simonbloke
17 Feb 2017 11:46 #11957 by simonbloke
Thanks.
The model is built, its the setting up of the ailerons, rudder and elevator i was thinking of.
Its the engine fuel system, electrics, radio and battery set up that's missing !!!
Has anyone got a rough plan of how the system of a petrol model should be, what i need to get etc
Simon
17 Feb 2017 11:55 #11958 by Chris73
These are the starting points I use, I am sure others have their own preference but I have found this gives you a safe starting point
Ailerons - 16 - 18 degrees
Elevator 10 - 12 degrees
Rudder 20 degrees
C of G just forward of the center of the wing tube
Engine set up
Make sure you use tygon fuel tube, I use a three line set up, one to fill the tank, one to the engine and one vent line, you will then need a kill switch and a way off operating the choke, a simple push rod that you can reach through the cowl should do
Time to create page: 0.620 seconds
