17 Feb 2017 11:59 #11959 by Chris73
Replied by Chris73 on topic New Model, first adventure into petrol
Below is a link to a good video on how to plumb the fuel tank
17 Feb 2017 12:32 - 17 Feb 2017 12:36 #11966 by JonTappin
Replied by JonTappin on topic New Model, first adventure into petrol
Hi Simon
The Rcexl remote ignition switch is good and not too expensive (link below). Some people use just a mechanical switch, but to me they are worth the extra as you can kill the engine in flight if necessary, which is a good safety feature and could save the model.
C of G should be between 25 and 30% of average wing chord. As Chris says this will be typically on or just in front of the tube.
Other than the tank plumbing, everything else is like any model, make sure you have sufficient battery capacity and that all linkages are of adequate strength etc
www.kingslynnmodelshop.co.uk/p2789/Petro...yPl9ICFYsW0wodQDcKJg
Last edit: 17 Feb 2017 12:36 by JonTappin.
  • simonbloke
17 Feb 2017 13:44 #11972 by simonbloke
Replied by simonbloke on topic New Model, first adventure into petrol
Cool Thanks.
What about the batteries, do i need one for ignition, two seperate batteries for reciever and servo's with somekind of power safe and regulator .
With the model came some bits and bobs all seems too complicated with two on off switches for two battery packs a couple of becs and a linear voltage reglator (Bec)
I have a 12 chanel futaba rx that is telemetry capable this will hopefully work if i have a reliable power sorce for the system ?
Simon
17 Feb 2017 17:49 - 17 Feb 2017 17:51 #11977 by kevinross
Replied by kevinross on topic New Model, first adventure into petrol
Ive advised Simon that the servos are not high voltage Li-po capable so have recommended he uses LiFe batteries for the radio to avoid needing regulators. - Simple is best.
I don't know if the Roto ignition unit will take Lipo voltage.
Last edit: 17 Feb 2017 17:51 by kevinross.
  • Stuartmck
17 Feb 2017 19:07 #11978 by Stuartmck
Replied by Stuartmck on topic New Model, first adventure into petrol
Ignition is 4.8-6.0V. Maybe LiFe, but not LiPo without regulator.
Stuart
17 Feb 2017 19:08 - 17 Feb 2017 19:09 #11979 by Phil Ford
Replied by Phil Ford on topic New Model, first adventure into petrol
Stuart beat me to it.
From the manual:
Roto ignition - Supply Voltage: 4-9V
Input current: 50mA – 500mA
Advance range goes up to 30 degrees advance
So Life 6.6v (2 cell) should be OK, Simon.
Last edit: 17 Feb 2017 19:09 by Phil Ford.
The following user(s) said Thank You: simonbloke
17 Feb 2017 19:53 #11981 by kevinross
JonTappin wrote: Hi Simon
The model already has a RCxel remote switch included.
  • simonbloke
17 Feb 2017 20:34 #11982 by simonbloke
Yep found the ignition switch and looking at batteries
Thanks very much for all your help with this
I am getting my head round it all
Simon
  • simonbloke
17 Feb 2017 20:41 #11983 by simonbloke
  • simonbloke
19 Feb 2017 19:05 - 19 Feb 2017 19:07 #12011 by simonbloke
Hi again, more question if you please !
The rcxel ignition switch has a magnetic key connected to it.
The futaba terminals have had the little key cut off .
Can anyone advice me which wires go were ?
Been trying to find some instructions on line but to no avail.....
Pics included.....
Simon
Last edit: 19 Feb 2017 19:07 by simonbloke.
Time to create page: 0.342 seconds
