Provost - Part 2
02 Jan 2018 10:16 - 02 Jan 2018 10:22 #15234 by flyingpete
Replied by flyingpete on topic Provost - Part 2
Awesome work Kevin, I'm sure the master upstairs will give you his approval..
If i can be of any help, give me a shout Kevin..
Last edit: 02 Jan 2018 10:22 by flyingpete.
06 Jan 2018 17:46 #15291 by kevinross
Replied by kevinross on topic Provost - Part 2
Tailwheel now complete . Doesn’t look like much extra but was actually double that in my first post due two attempts on the steering tiller and a complete rethink on the suspension which has increased weight to 100 gm (4ozs) but should be OK with an estimated AUW ITRO 20 lbs
last two shots - Because the tiller swings when the suspension is compressed, the closed loop connection has to pitch and the wires require some method of spring compensation so made this mock up to prove everything
06 Jan 2018 20:43 #15293 by DaveBright
Replied by DaveBright on topic Provost - Part 2
Excellent work Kevin. Looks really really good. You're doing him proud!
07 Jan 2018 16:50 #15297 by flyingpete
I'm not an engineer but i can imagine the time and effort that has gone into producing the tail wheel Kevin!! Outstanding work and look forward to my easy task with the canopy?????
07 Jan 2018 17:27 - 07 Jan 2018 17:28 #15298 by kevinross
flyingpete wrote: I'm not an engineer but i can imagine the time and effort that has gone into producing the tail wheel Kevin!! Outstanding work and look forward to my easy task with the canopy?????
Thanks Pete
Just counted up every screw, rivet & piece of metal which i had to work and surprised myself = 51 !!!
Ive striped it in preparation for painting when the next task is complete - The main legs. -
Last edit: 07 Jan 2018 17:28 by kevinross.
07 Jan 2018 18:00 #15299 by AlanF
Replied by AlanF on topic Provost - Part 2
Impressive stuff Kevin, watching this thread with interest. Is this project going to be a home for Frank's Saito or do you have other plans for powering the Provost?
07 Jan 2018 18:19 #15301 by kevinross
AlanF wrote: I Is this project going to be a home for Frank's Saito or do you have other plans for powering the Provost?
Obviously the Saito is the intended and primary choice but i have major concerns on how to extract sufficient cooling air while retaining a reasonable scale appearance of the cowl. Brian Winch has published many articles about cooling these engines.
12 Feb 2018 20:50 - 12 Feb 2018 20:51 #15760 by kevinross
Provost U/C nearing completion. Further to the show & tell last Friday i've now received the LED reflectors for the landing lights - plus i get an anal bonus for matching two alloy rings for the the reflectors. Just need to source suitable LED's
last photo are the parts ex Franks workshop. the rest are my progress.
Last edit: 12 Feb 2018 20:51 by kevinross.
18 Feb 2018 22:31 #15807 by kevinross
Unfortunately, the wing has developed a 3 Deg warp between the tips but 2 days after removal of the top skin, the structure has relaxed to within 0.8deg. I hope careful replacement using there clamps should produce a good result.
Many thanks to Flying Pete for offering to help but i like a challenge. (i think)
05 Mar 2018 21:41 - 05 Mar 2018 21:41 #15890 by kevinross
Canopy arrived last week c/w outer shroud which gas to be make the outer frame
started by fixing the canopy slide rails
Last edit: 05 Mar 2018 21:41 by kevinross.
Time to create page: 0.389 seconds
