Provost - Part 2
05 Mar 2018 21:54 - 05 Mar 2018 21:54 #15891 by kevinross
Replied by kevinross on topic Provost - Part 2
made a start on the fwd canopy reinforcement frame by laminating 6 layers x 0.5mm cross ply on a frame inside the canopy
frame trimmed to size then cut part way thru from the back
Then when its fixed, I can use this slit as a guide to separate the fixed and sliding section
Last edit: 05 Mar 2018 21:54 by kevinross.
08 Mar 2018 21:49 - 08 Mar 2018 22:03 #15920 by kevinross
Getting close to the final fit of the canopy - With the moulding held in place with masking tape and a bungee lightly pulling the canopy onto the coaming i've pulled an abrasive strip back and forth
Last edit: 08 Mar 2018 22:03 by kevinross.
08 Mar 2018 23:15 #15921 by DavidTappin
Replied by DavidTappin on topic Provost - Part 2
I like the abrasive strip trick, very neat Kevin. Is that original Ross thinking or something I should have known about?
09 Mar 2018 07:38 #15923 by kevinross
DavidTappin wrote: I like the abrasive strip trick, very neat Kevin. Is that original Ross thinking or something I should have known about?
The abrasive strip was my idea - the elastic bungee was Mrs R's response to my offer of a canopy securing apprentice !
12 Mar 2018 21:26 #15971 by kevinross
Ive been distracted the last few days but have now progressed the cockpit frame - not sure if you can use this link but have a go.,
www.dropbox.com/s/0vjytezu97k24dc/IMG_5994.mov?dl=0
The sliding frame is successful ! - Now masking off the canopy ready for adhesive. Thanks to JT's tip I will use these magnets to assist location. Still thinking epoxy & micro balloons.
12 Mar 2018 22:04 #15973 by JonTappin
Replied by JonTappin on topic Provost - Part 2
Fingers crossed the magnets work Kevin, never actually tried it myself!
17 Mar 2018 07:53 #16022 by kevinross
Canopy progress has halted while a fabricate a second frame to help another UK builder who doesn't have the tooling for such specialised jobs. (a bit more practice is just what I need )
So if the second frame is better that the first - what would you do ?
17 Mar 2018 08:03 #16023 by MikeSeale
Replied by MikeSeale on topic Provost - Part 2
Be honest at this stage and tell the other chap that you're going to keep the best one.
17 Mar 2018 08:53 #16027 by Brian
Replied by Brian on topic Provost - Part 2
If the second frame turns out better.............charge him extra!
17 Mar 2018 21:21 - 17 Mar 2018 21:22 #16056 by kevinross
Making a copy of the frames was much easier than the originals which i had to build using the profile of the canopy.
Last edit: 17 Mar 2018 21:22 by kevinross.
Time to create page: 0.383 seconds
