Provost - Part 2
7 years 8 months ago #15807 by kevinross
Replied by kevinross on topic Provost - Part 2
Unfortunately, the wing has developed a 3 Deg warp between the tips but 2 days after removal of the top skin, the structure has relaxed to within 0.8deg. I hope careful replacement using there clamps should produce a good result.
Many thanks to Flying Pete for offering to help but i like a challenge. (i think)
7 years 7 months ago - 7 years 7 months ago #15890 by kevinross
Canopy arrived last week c/w outer shroud which gas to be make the outer frame
started by fixing the canopy slide rails
Last edit: 7 years 7 months ago by kevinross.
7 years 7 months ago - 7 years 7 months ago #15891 by kevinross
made a start on the fwd canopy reinforcement frame by laminating 6 layers x 0.5mm cross ply on a frame inside the canopy
frame trimmed to size then cut part way thru from the back
Then when its fixed, I can use this slit as a guide to separate the fixed and sliding section
7 years 7 months ago - 7 years 7 months ago #15920 by kevinross
Getting close to the final fit of the canopy - With the moulding held in place with masking tape and a bungee lightly pulling the canopy onto the coaming i've pulled an abrasive strip back and forth
7 years 7 months ago #15921 by DavidTappin
Replied by DavidTappin on topic Provost - Part 2
I like the abrasive strip trick, very neat Kevin. Is that original Ross thinking or something I should have known about?
7 years 7 months ago #15923 by kevinross
DavidTappin wrote: I like the abrasive strip trick, very neat Kevin. Is that original Ross thinking or something I should have known about?
The abrasive strip was my idea - the elastic bungee was Mrs R's response to my offer of a canopy securing apprentice !
