New Toy
7 years 7 months ago #16125 by Chris73
Replied by Chris73 on topic New Toy
Only managed to get a couple of hours on the plane tonight
So decided to get a few of the smaller jobs done
Tail wheel was disassembled and then reassembled using blue loctite on all screws, then got the fuel dot fitted and plumbed the fuel tank
7 years 7 months ago #16126 by Chris73
Some people have had problems with the supplied hardware, so not wanting to risk it, all control rods and ball links were replaced with Secraft ones
Dont know if it was needed, and I have always used the hardware supplied from Extreme Flight in the past, but didnt want to find out the hard way that there was an issue
7 years 7 months ago #16127 by Chris73
Nest job was to make up the extension leads for the elevators and rudder, I use Powerbox cable and crimps, and then braid all cables to prevent them from rubbing against anything
7 years 7 months ago #16128 by Chris73
Final job for this evening was to install the elevator servos and make up the control linkages (Installing the servo wasn't fiddly at all :( )
I use two drill bits the correct size to make screwing the ball links on easier
7 years 7 months ago #16132 by simondean
Replied by simondean on topic New Toy
Can't believe your not done yet! The Extra was finished overnight!
7 years 7 months ago - 7 years 7 months ago #16133 by Phil Ford
Replied by Phil Ford on topic New Toy
simondean wrote: Can't believe your not done yet! The Extra was finished overnight!
:lol:
Mind now Simon your on sticky ground there - your project and progress.;)
Last edit: 7 years 7 months ago by Phil Ford.
