Carb rebuild kits
6 years 6 months ago #19165 by kevinross
Replied by kevinross on topic Carb rebuild kits
In case you dont have this detail
www.walbro.com/tech-tips/metering-lever-setting/
  • AlanF
6 years 6 months ago #19167 by AlanF
Replied by AlanF on topic Carb rebuild kits
Thanks Kevin, I think it's set too low at the moment so if I get lean running after the rebuild I'll reset it.
6 years 6 months ago #19169 by kevinross
Floppy flaps on the pump section normaly settle when the engine is running. If the needle lever is not set correctly - that could be the problem. - I would adjust to the manual before proceeding.
6 years 6 months ago #19170 by DaveBright
Replied by DaveBright on topic Carb rebuild kits
Was a day of floppy flaps at ththe field today!!
  • AlanF
6 years 6 months ago #19172 by AlanF
davidbright wrote: Was a day of floppy flaps at ththe field today!!
Well you can't leave that there Dave, the story must be told.
6 years 6 months ago - 6 years 6 months ago #19173 by kevinross
I hope not the sort of flops as happened on Wed
Last edit: 6 years 6 months ago by kevinross.
Time to create page: 0.255 seconds
