P51 Conversion to DLE20RA
21 Apr 2015 08:59 #4303 by Phil Ford
Replied by Phil Ford on topic P51 Conversion to DLE20RA - SOLVED
Hi Frank, hope you feel a bit better soon and can get up the field. Thanks for the offer, may take you up on that, but not sure when at the present moment. I assume your neighbours are used to some noise.... :lol: You got something to restrain the fuselage? Probably have to be a morning. Going off subject momentarily,
Frank, Wots Wot are back and I now have one (pre-ordered ages ago and suddenly turned up). Gonna fit mine with a 4030/08 laying around on 6 cell (1200 watts) However, there has to be a downside and a forthcoming post will explain what, why, etc. ;)
Kevin, mine is a Walbro and is fitted to the 20, 35's. The CDi is supposedly the same unit for the 20,35,55. (DLE changed the capacities because of counterfeit copies) However, rumour has it that specifically the 20's timing is 32 deg rather than the the standard 28. Not that I am concerned because I don't have that issue, I am just commenting for general info.
21 Apr 2015 19:23 #4305 by DaveBright
Replied by DaveBright on topic P51 Conversion to DLE20RA - SOLVED
Glad you got it sorted Phil..... Can be frustrating chasing a ghost!
28 Apr 2015 15:17 - 28 Apr 2015 15:26 #4336 by Phil Ford
Getting there now, progress is showing at last. Engine installed, all the electrics, wings completed. Repainted cowl and top of fuse to replicate a Yellow Nose Mustang of 351st Fighter Group. Got to hand paint the canopy frame though. Lots of tidying up to do once everything is checked out twice. ;)
Engine fit was tight, I knew it would be, but sits nicely. Took some thinking on getting the throttle and choke controls (the latter still neeeds a better way of operating it but minor issue) into the main fuselage. Had to make up a few custom mods to allow the RX to sit where I wanted it, seeing as the regulator was in it's position. Prop is MAS 15x8 also Inca yellow tips.
The yellow acrylic paint job on the cowl and fuselage top is Rover Inca Yellow, the nearest I could find to match the spinner. The blue rudder was sprayed in Mercedes wheel silver but is isn't as "silvery as the fuselage covering but I'll think on that one. I wanna see it fly first... :lol:
More images to come as I stumble along.... :lol:
Last edit: 28 Apr 2015 15:26 by Phil Ford.
29 Apr 2015 08:04 #4338 by kevinross
Replied by kevinross on topic P51 Conversion to DLE20RA - SOLVED
Hi Phil
I'm curious (and concerned) about the Fuel tank
- Does the photo show the tank fwd of the L/E but facing rearwards ?
- Is it aft of the wing T/E
- Or is it in in the upper deck space
29 Apr 2015 08:33 - 29 Apr 2015 08:34 #4340 by Chris73
Replied by Chris73 on topic P51 Conversion to DLE20RA - SOLVED
Hi Phil
Looks like it is getting close now, is that the standard DLE 20 exhaust?? If it is it will be LOUD
Last edit: 29 Apr 2015 08:34 by Chris73.
21 Jun 2015 17:46 - 21 Jun 2015 17:48 #4966 by Phil Ford
kevinross wrote: Hi Phil
The tank is in it's designated position but is reversed to allow for a small gap between the tank end and firewall. This is because the carb sits partly in firewall hole that the tank would've sat in.
I have had the Muzzie running again for something to do after modifying the choke and throttle control. ;) In the near future will get it up the field for some tuning.
Chris73 wrote: Hi Phil
Looks like it is getting close now, is that the standard DLE 20 exhaust?? If it is it will be <strong>LOUD</strong>
It didnt' sound loud in my drive... ;)
Last edit: 21 Jun 2015 17:48 by Phil Ford.
21 Jun 2015 18:25 #4967 by Chris73
Trust me the standard DLE exhausts are useless, you can pick up a reasonably cheap Pitts exhaust which will make a big difference
21 Jun 2015 18:41 #4968 by JonTappin
Replied by JonTappin on topic P51 Conversion to DLE20RA - SOLVED
PhilF51 wrote: The tank is in it's designated position but is reversed to allow for a small gap between the tank end and firewall.
Don't think that will allow the clunk to work very well Phil, if it stays at the back ( now front) of the tank it will be out of the fuel when the nose is raised. If it does drop to the rear of the tank it will get caught in the pipes around the bung end then be out of the fuel when you are inverted (or upright depending on where it gets caught). You might want to reconsider this arrangement!
21 Jun 2015 18:49 #4969 by Phil Ford
Cheers Guys, I'll rethink the tank layout Jon but I got the idea from RC Forums :unsure: where they had similar issues with gas conversions in scale models and they had the tank reversed. I must admit I thought it might be an issue with the clunk up front, but maybe would work if the tank is short and also in this case it is side on. But on the other hand you have G-forces at work also which will attempt to push items and fuel to rear.
I will have look see for an alternative Pitts exhaust then..... ;)
21 Jun 2015 19:01 - 21 Jun 2015 19:09 #4970 by DaveBright
www.motorsandrotors.co/index.php?main_pa...info&products_id=179
Any use?
If you can't fit the tank in that you have, what about two smaller tanks that can go in the right way round and plumbed into a central pickup (uat).
Or the tank the right way round just set back a little?
Last edit: 21 Jun 2015 19:09 by DaveBright.
Time to create page: 0.355 seconds
