Electric pump
10 years 6 days ago #6531 by Chris73
Replied by Chris73 on topic Electric pump
I have been using the Kavan pump in my fuel can for about a year now without any issues (I know i shouldn't have said that :dry: )
Even if the seals do start leaking they are only a few pounds for a complete set, i was advised to run the pump in reverse at the end of the flying sessions so there is no fuel left in the pump, seems to have worked so far :)
10 years 6 days ago #6537 by MikeSeale
Replied by MikeSeale on topic Electric pump
Re. using air pressure to fill a tank...
I know this is being asked in terms of pumping kerosene, but would remind people of the dangers of methanol in your eyes...it can cause blindness. I do not know whether kerosene or petrol have similar hazards. The risk of a pressurised tank surely cannot be worth considering when we have conventional pumps available, even if they do need a little maintenance from time to time?
10 years 6 days ago #6538 by
Replied by on topic Electric pump
MikeSeale wrote: Re. using air pressure to fill a tank...
Hi Mike - I agree with the dangers of methanol but I would think the output pressure of a standard motorised pump would be far greater than that of a pressurised tank. The pressure generated by a fuel pump would be uncontrolled and unknown so the possibility of a fuel line popping off an inline filter or filling adaptor would be greater. The flow rate from the Jerrycan would be increased by using a larger bore tube which would allow a low air pressure to be used.
10 years 6 days ago #6540 by MikeSeale
I've said my piece and do not intend trying to justify the advice offered
  • Banned
  • Banned
10 years 6 days ago - 10 years 6 days ago #6546 by flyingpete
Replied by flyingpete on topic Electric pump
Thanks guy's for your input B) I won't be using air pressure as the retracts are electric
Last edit: 10 years 6 days ago by flyingpete.
10 years 1 day ago #6634 by
Hi GUYS, Just like to point out that any pressurzed vessel used in a public place (with fuel) requires a test cert and must be tested to 21/2 times working pressure first time then 11/2 times every year, you will need some body like me with the paperwork to test these or a outside person which could cost, if its steel every year, copper every 2 years think about it :ohmy:
