Electric pump
10 years 1 day ago #6639 by
Replied by on topic Electric pump
Hi Frank
So it looks like scratch the pressurised Jerry-can idea then!!
BTW - What constitutes a 'pressurised vessel'. Would that include the 'pressurised fuel tank on most if not all glow powered models? :whistle: :silly:
10 years 1 day ago #6649 by
Hi Ron your on board fuel tank is open through the exhaust fitting so any over pressure would escape through that, also the areas and volume are very small a jerry can a bit larger, a coca cola can can stand well over 100psi (8bar) to the young ones but the shape becomes differant :silly:
10 years 1 day ago #6650 by
Interestingly... some IC tanks are pressurised....
the YS and some OS engines pressurise the tank from the crankcase pressure and a one way valve.
this then supplies a constant pressure fuel to a special regulator on the carb.
looove YS engines.
Time to create page: 0.268 seconds
