Christmas Curare
9 years 11 months ago #7029 by
Replied by on topic Christmas Curare
The only thing about the electric version if you go with the recommended motor is that you quite literally have to take a hammer to it!
9 years 11 months ago #7031 by Phil Ford
Replied by Phil Ford on topic Christmas Curare
Chris001 wrote: The only thing about the electric version if you go with the recommended motor is that you quite literally have to take a hammer to it!
This version does have a hatch now for battery insertion. The battery size is limited mainly by the width of the "tank area". Also the weight on average is increased by 300 gms using electric. When I get round to assembling it, I will be deciding on motive power but I am leaning towards using the OS55AX extracted from the Cherokee. Plus I only need a Genesis pipe. You'll know when the thread moves to a category... ;)
9 years 11 months ago #7033 by JonTappin
Replied by JonTappin on topic Christmas Curare
Phil
If it helps your decision, here is a link to a review using an electric set up.
www.sussex-model-centre.co.uk/shopcontent.asp?type=News
9 years 11 months ago #7034 by JonTappin
If you are having trouble sleeping I could scan my review for you as well :)
9 years 11 months ago #7035 by Phil Ford
JonTappin wrote: If you are having trouble sleeping I could scan my review for you as well :)
Jon, I had already read that review on Sussex. It was that review that made me plump for the Curare. ;)
How is the tuned pipe located because I assume you have to slide the wing under?
I would be grateful for your review if you could scan it up. I really fancy noise n oil :lol: but somehow electric gives less flight time but it is simpler in use. Decisions decisions :(
9 years 11 months ago - 9 years 11 months ago #7036 by JonTappin
As you wish!
Pipe is secured under the wing on a supplied bracket with a cable tie, I leave the pipe attached to the silicon joiner when the wing is off.
Part one of the review, the build (assembly :) )
Last edit: 9 years 11 months ago by JonTappin.
