Extreme Flight 104" Extra
11 Feb 2016 13:31 #7966 by Chris73
Extreme Flight 104" Extra was created by Chris73
Here goes, I picked up the plane last night from Probuild, the plane came in three large boxes (only just fitted in the car) and was very well packed, unpacked everything and the quality is superb, nothing damaged in transit and the kit comes with a full usable hardware kit, wing bags, stab bags and a bag for the canopy
The covering looks really good with no wrinkles
Tonight's jobs
1) Go over the whole airframe with the covering iron (I always do this no matter how good the covering looks)
2) Hit every joint i can get to with CA
3) Start gluing in the hinges (There are loads of them :( ) For the rudder and elevators i will do them in one go, for the ailerons I will glue the hinges in the aileron first, let that dry and then glue the hinges into the wing
I will post some pics later when i get home
Question, i will be sealing the hinge gap on the ailerons and elevators, does anybody seal the gap on the rudder??
11 Feb 2016 13:39 #7967 by MikeSeale
Replied by MikeSeale on topic Extreme Flight 104" Extra
Chris73 wrote: Question, i will be sealing the hinge gap on the ailerons and elevators, does anybody seal the gap on the rudder??
I can't answer this but:
1. What is the benefit of sealing the hinge gap on the aileron and elevator?
2. How easy is it to seal the gap?
3. Does sealing the gap have any drawbacks?
Depending on how YOU answer these questions will determine whether YOU choose to seal the rudder hinge gap or not.
11 Feb 2016 14:19 #7968 by flyingpete
Replied by flyingpete on topic Extreme Flight 104" Extra
Chris73 wrote: Here goes, I picked up the plane last night from Probuild, the plane came in three large boxes (only just fitted in the car) and was very well packed, unpacked everything and the quality is superb, nothing damaged in transit and the kit comes with a full usable hardware kit, wing bags, stab bags and a bag for the canopy
Tonight's jobs
Nice easy build Chris! Can't see it being a problem for a maiden this saturday?
11 Feb 2016 14:43 - 11 Feb 2016 14:48 #7969 by JonTappin
Replied by JonTappin on topic Extreme Flight 104" Extra
I haven't done my rudder as I have made it removable, if you aren't doing that then seal it with the other surfaces
1. What is the benefit of sealing the hinge gap on the aileron and elevator? The theory is that it increases control power and reduces the risk of flutter as no air is allowed to pass through the gap, I have done both and can't honestly confirm how much if any difference it makes. You would have to fly alot both ways with one model to confirm. It does make the hingeline look a lot neater though
2. How easy is it to seal the gap? Very easy, I have done it with clear covering, sticky tape and covering the same colour as the model, covering is easier than sticky tape to get neat
3. Does sealing the gap have any drawbacks? None that I am aware of
I have added my opinions on your questions Mike, I know how much everybody values my opinions :dry:
Last edit: 11 Feb 2016 14:48 by JonTappin.
11 Feb 2016 16:59 #7971 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Wont be flying this weekend Pete, apparently work said i have to be there :angry:
Maiden next weekend though :)
Thanks Jon, I will seal the rudder as well
11 Feb 2016 17:48 #7974 by AlanF
Replied by AlanF on topic Extreme Flight 104" Extra
Chris73 wrote: Wont be flying this weekend Pete, apparently work said i have to be there :angry:
Blimey Chris that's quick!
I used Blenderm tape to seal hinge lines on the Extra and the Giles which seem to work ok. Underside only on ailerons and elevator and both sides on rudder. I'm not sure if it's the neatest solution but it sticks well and is reasonably easy to apply.
11 Feb 2016 21:57 #7975 by Chris73
Got a bit done tonight, run the iron over everything, CA everything I could get to, fuel proofed the landing gear plate, hinged the elevators and rudder. While the epoxy was drying I plumbed and fitted the fuel tank and then went back and epoxied on the control horns to the elevators
11 Feb 2016 22:40 #7976 by Chris73
Fuel tank fitted :)
12 Feb 2016 09:49 - 12 Feb 2016 09:49 #7977 by AlanF
I like the colour scheme.
Was the CA added as a precaution or were there signs of a lack glue. I know it's not the same quality as the EF but my Giles had one wing tube largely un-attached at the root and on trial fitting the stabs on the Edge the anti-rotation pins disappeared into the stab root. They're going to be a b*st*rd to get back out :(
Have you decided on engine and servos yet?
Last edit: 12 Feb 2016 09:49 by AlanF.
12 Feb 2016 10:15 #7978 by Chris73
The CA was just added as a precaution, everything seemed to be well glued but Extreme Flight recommend you do this, just in case
Engine will be 3W110 with MTW tuned pipes, servos are Savox 1270TG
Time to create page: 0.356 seconds
