Extreme Flight 104" Extra
14 Feb 2016 19:45 #8012 by AlanF
Replied by AlanF on topic Extreme Flight 104" Extra
Chris73 wrote: Not much left to do now
Fit fuel dot
Fit switches and tidy up the wiring
Make the engine baffles
Silver solder the headers :dry:
Then check the C of G before locating the ignition battery
Apparently I have to tidy up before I do anything else :whistle:
Impressive stuff Chris - have you slept at all this weekend?
Are you going to send a snotagram to EF regarding the tail wheel? I'm sure they would welcome customer feedback.
14 Feb 2016 20:34 #8013 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Persuaded the missus it would be better to fit the fuel dot before I tidied up as it would just make more mess ;) so that's one less thing to do.
I really should learn to tidy as I go, took me ages :oops:
Simon, yes I have the pipes already
Alan, whilst the tail wheel was a really bad fit in reality it only took a couple of minutes with the dremel to fix it. I wonder if I have a 50cc one instead of a 100cc one. I will compare it to Simon's and if need be ask EF for the correct one
14 Feb 2016 22:04 #8016 by DaveBright
Replied by DaveBright on topic Extreme Flight 104" Extra
Can't believe how slowly this has gone together..... Yawn
I of course jest. :) great stuff mate.
15 Feb 2016 20:53 #8026 by simondean
Replied by simondean on topic Extreme Flight 104" Extra
My HK spinner arrived today. Looks very nice. Not sure where to source a m6 bolt long enough to secure it ,Spinner is 7" long ? Any suggestions?
15 Feb 2016 21:12 #8029 by Chris73
Mine came with the bolt, but you could try Westfield Fastners they seem to have a good selection
16 Feb 2016 07:20 #8031 by flyingpete
Replied by flyingpete on topic Extreme Flight 104" Extra
simondean wrote: My HK spinner arrived today. Looks very nice. Not sure where to source a m6 bolt long enough to secure it ,Spinner is 7" long ? Any suggestions?
Simon, are you sure it is m6? as they are normally m5
16 Feb 2016 19:48 #8032 by simondean
Yes your right Pete ,slip of the fingers it's M5 .
19 Feb 2016 08:07 #8043 by JRI
Replied by JRI on topic Extreme Flight 104" Extra
I have a similar problem to Simon - the supplied M6 spinner screw doesn't reach or fit the M5 crankshaft thread and adapters are n/a. But I Found High-tensile M5x120 & M5x130 on the modelfixings website at www.modelfixings.co.uk/high_tensile_steel_caps.htm .
The longest screw reaches the crankshaft for my spinner but I will need to sleeve the nose of the spinner from 6mm to 5mm.
19 Feb 2016 19:09 #8044 by simondean
Found a company dealing with M5 in suitable length but they only supply to trade . Got a name in the area but not had time to investigate yet.
19 Feb 2016 20:19 #8045 by kevinross
Replied by kevinross on topic Extreme Flight 104" Extra
simondean wrote: Found a company dealing with M5 in suitable length but they only supply to trade . Got a name in the area but not had time to investigate yet.
Simon - also available at westfield fasteners are these which you could use in combination with some HT studding to extend the the longest 5mm bolt . Bottom the spinner bolt and a piece of studding into this long nut.
www.westfieldfasteners.co.uk/A2_Nut_HexL...LRhMsCFRYTGwodkNQNkg
Time to create page: 0.574 seconds
