Extreme Flight 104" Extra
13 Feb 2016 20:19 #7998 by flyingpete
Replied by flyingpete on topic Extreme Flight 104" Extra
Chris73 wrote: Engines in :woohoo:
Going to try it without the velocity stack to start with to save cutting the cowl, not really sure what it does anyway??
Hmmmmmm velocity stack's!! Takes me back to when i was a bit younger!! :dry:
13 Feb 2016 20:36 #7999 by simondean
Replied by simondean on topic Extreme Flight 104" Extra
Quick work so far chris. How are you going to do baffles in cowl ? Not easy job .yet to do mine.i know what to do but not sure easy way to achieve,especially if a close fit to cyclinder heads to be done.
13 Feb 2016 20:50 #8000 by Chris73
Replied by Chris73 on topic Extreme Flight 104" Extra
Simon I just use an old bit of card to get the shape and size I want, then transfer that to some lite ply and epoxy in place
Starting to take shape now, the spinner will need to be repainted at some point as it is the wrong shade of red, but it's close enough for now
13 Feb 2016 22:30 #8001 by simondean
Are you going for a pull pull on rudder or servo in tail ?
13 Feb 2016 22:33 #8002 by Chris73
I have put the rudder servo in the tail, but the 3W is a bit heavier than the DA . Might be worth checking the C of G before making a decision
14 Feb 2016 12:07 #8003 by Chris73
First little issue, went to fit the tail wheel and the holes in the carbon skid do not line up with the blind nuts in the fuss, not a major problem will just have to elongate the holes in the skid, but to be honest they are a long way off :(
14 Feb 2016 13:33 #8004 by JonTappin
Replied by JonTappin on topic Extreme Flight 104" Extra
That's odd, mine was perfect, they have obviously changed something. Redrilling the carbon part shouldn't be an issue though.
The repair on mine is coming along, just slow going hand cutting the ply parts for the front end, will do a separate thread when I have time.
14 Feb 2016 14:06 #8005 by Chris73
Must have been a Friday afternoon one, where the bolt goes through for the tail wheel should have been an 8mm hole but was only drilled to 6mm, like you say easy fix
14 Feb 2016 17:18 #8008 by Chris73
Not much left to do now
Fit fuel dot
Fit switches and tidy up the wiring
Make the engine baffles
Silver solder the headers :dry:
Then check the C of G before locating the ignition battery
Apparently I have to tidy up before I do anything else :whistle:
14 Feb 2016 19:23 #8011 by simondean
My tail set up was spot on.will check cof g first before doing rudder servo. You have tuned pipes already?
Time to create page: 0.344 seconds
