Aero Navigation Lights
27 Jan 2017 13:01 - 27 Jan 2017 13:02 #11730 by Phil Ford
Replied by Phil Ford on topic Aero Navigation Lights
Right - Back to Navigation lights....... ;) Made up a board with headers making the processor plug in (easier to update software). The outputs are sent to the Darlington array which can handle higher currents which in turn powers the LEDs. Image 1. This board would be okay for a plane which has 5.5 - 6.6v available with small leds.
Image 2. This 12 volt board can be powered by a 3 cell lipo (or tap off three pins from the balance ports of main power pack) but because the voltage could be above 12 volts on a fully charged Lipo then a regulator is required. Note the blank space made for it. (Regulator did not arrive today :( ) The board is approx 50 mm square. This one is destined for the Twin Otter. The landing lights already fitted are 20,000mcd.
If this works in practice then I may etch a proper circuit board for future uses or if a member want a decent system.
The software is set as : Navigation Lights On when receiver is switched on and TX signal good. Gear switch turns on landing lights. If receiver loses power or signal then ALL lights come on. :ohmy:
Last edit: 27 Jan 2017 13:02 by Phil Ford.
31 Jan 2017 17:10 #11793 by Phil Ford
Regulator and transients filters now soldered in. Module tested and working great. (It does now after a few hours of scratching head and multimeter checking - left out one link. Doh! :( ) The board is powered from either a 7.4v lipo or 6.6 v Life. The processor gets 5 volt regulated and the Darlington Array handles any voltage up to 40 volt on it's output pins but in my module designed to use input voltage, 6.6 - 7.4v. All plugs and sockets are JST -SH type so standard servo leads can be utilised. ;) However, I am making up my own leads.
Now that's done I can start the arduous task of fitting and wiring leds into the plane..
31 Jan 2017 21:26 #11798 by JRI
Replied by JRI on topic Aero Navigation Lights
That 5V reg looks tiny Phil, have you tested how hot it gets under full load (or is full load the processor only?)
31 Jan 2017 21:41 #11801 by Phil Ford
John, it's a 100 ma regulator which only has to power processor. The processor can take 40 ma max per pin, normally 20 ma but the board can only handle 200 ma maxed out. Hence the Darlington. The Array can handle 500 ma per pin max.
Mind you I could've used MosFets but don't need 10 amps per channel unless I was using car headlight bulbs for lights.. :lol:
01 Feb 2017 07:43 #11803 by DaveBright
Replied by DaveBright on topic Aero Navigation Lights
'The Darlington array' sounds cool.
01 Feb 2017 08:41 #11804 by Brian
Replied by Brian on topic Aero Navigation Lights
I thought the Darlington Array was a film by Steven Spielberg
01 Feb 2017 11:12 #11805 by kevinross
Replied by kevinross on topic Aero Navigation Lights
DaveBright wrote: 'The Darlington array' sounds cool.
In Darlington they have a famous ARRAY of bricks
01 Feb 2017 12:35 #11806 by Chris73
Replied by Chris73 on topic Aero Navigation Lights
Woah there, off topic alert :ohmy:
Better lock the thread :P
01 Feb 2017 13:51 #11807 by DaveBright
01 Feb 2017 15:06 #11808 by JRI
Chris73 wrote: Woah there, off topic alert :ohmy:
With Loctite?
Ps, this is a Darlington Pear
Time to create page: 0.366 seconds
