Freewing EDF Group
  • AlanF
28 May 2019 08:53 #19661 by AlanF
DavidTappin wrote: Alan wrote
Despite being in widespread use, the misspelling definately comes in for considerable scorn. The Urban Dictionary has a separate entry for definately, which it defines as: 'Idiot-speak for “definitely”. One of the most common moronic misspellings found on the Internet'.
Watch out Alan, you might get your wrist slapped, mine’s still stinging.
The quote did make me smile. I definitely wouldn't have noticed if Jon hadn't pointed it out in his subsequent post.
28 May 2019 12:58 #19666 by JonTappin
My phone actually offers me both versions when I start typing defin.... That can't be right!!
28 May 2019 13:13 - 28 May 2019 13:15 #19667 by Phil Ford
JonTappin wrote: My phone actually offers me both versions when I start typing defin.... That can't be right!!
Best way out and to confuse the predictive text app is to use military speak version "defo" :lol:
Not sure where this thread is going or is it the Title? Blame me!B)
Last edit: 28 May 2019 13:15 by Phil Ford.
  • AlanF
28 May 2019 14:37 #19668 by AlanF
Just to drag things back on track.
The build is complete and including a 1600mAh Zippy a small amount of bullet tape and no wing tanks the flying weight has come out at 567 grams. The specified 470 grams looks to be very optimistic.
A quick run up shows the fan drawing a max of 34A at 400 watts. I need to keep an eye on the ESC as it's rated a 30A.
Given the power draw the flight time on a 1600 might be a bit marginal ( probably < 3 minutes) and making space for a 2200 might be the best choice.
Anyway, a maiden isn't going to happen this week but hopefully some time next week.
28 May 2019 15:19 #19669 by JonTappin
I'm going to stick with the 2200, wasn't getting much more than 4 minutes on Saturday, so don't want to go smaller.
I'm going to try to put a servo in the tail for rudder, which together with moving the battery as far back as I can, will give me the correct cg.
Having flown it, I'm not worried about the weight, even with the forward cg, it landed plenty slow enough for a jet!
28 May 2019 15:27 - 28 May 2019 15:41 #19670 by Phil Ford
Just for the Sabre boys.;) Mine balancing 3 inch CG with Nanotech 2200 3S <90C pack in middle of bay. Clamp ammeter gives 35 amps at WOT. A decent ESC should cope with a few quick bursts up to 40 amp. Soon find out :dry: maybe next week if weather improves. AUW = 620gms
Last edit: 28 May 2019 15:41 by Phil Ford. Reason: Add AUW
28 May 2019 15:51 #19671 by JonTappin
Not sure about 'a few quick bursts' Phil, my MIG needed most of the power, most of the time, it's not over powered!!
28 May 2019 15:52 - 28 May 2019 15:53 #19672 by Phil Ford
:( Could be a lot of flame outs then or is it flames?
Calculating at 12.5 volts at 35 amps pans out at 446 watts
Last edit: 28 May 2019 15:53 by Phil Ford.
  • AlanF
28 May 2019 16:09 #19673 by AlanF
I'm going to stick with what I've got - for science.. I'll change out to 2200 after the maiden.
Something to think about though: Just 'taxied' the Sabre up and down the (slightly damp) lawn and noticed a massive difference in thrust when running without the canopy. There was a mention on YouTube of the Mig benefiting from cheat holes.
Here about 7 minutes in
28 May 2019 17:23 - 28 May 2019 17:30 #19675 by Phil Ford
Yes, Alan there are cheat hole videos on Utube. I did not mention it in case of undue scorn. I think I saw a square hole just forward of the fan and covered in some fine plastic mesh. Glad you brought the subject up then you can take the flak.....:lol:
It was mentioned here but looks awful and probably weakens the wings. Then sorts of peters out so maybe no advantage
www.rcgroups.com/forums/showthread.php?2...wing-64mm-F-86/page3
Last edit: 28 May 2019 17:30 by Phil Ford.
Time to create page: 0.445 seconds
