Advice gas turbine
5 years 6 months ago #21689 by JonTappin
Replied by JonTappin on topic Advice gas turbine
I think you've got a bargain there with that little time on the turbine!
  • Wingman1962
5 years 6 months ago #21690 by Wingman1962
Replied by Wingman1962 on topic Advice gas turbine
Yes I think so Jon, got it for 950 in the end, still got to collect from kent so some expense there.
5 years 6 months ago #21692 by JRI
Replied by JRI on topic Advice gas turbine
My Jetcat P80 has > 50 hours on the clock and still going strong. If its a kerostart conversion you have, you may occassionaly need to de-crud the ceramic glow plug in kerosene in an ultrasound cleaner (you a welcome to use mine). This gives you a very reliable startup - so long as you have a good (high 'C' rating) battery pack of around 3000mA.
  • Wingman1962
5 years 6 months ago #21693 by Wingman1962
Ok thanks, I'm new to gas turbines so I will take that onboard. It comes with the batteries so hopefully they will be adequate.
  • Wingman1962
5 years 6 months ago #21754 by Wingman1962
Hi Jon. Got the Turbinator home and have been reading up on settings and procedures. Got a question tho, the previous owner ran the turbine on Jet A1 fuel, should I continue to use that and where can I get it.
Thanks John
5 years 6 months ago - 5 years 6 months ago #21755 by JonTappin
Most of us run kerosene, you'll be fine with that. I get mine from
Red Eagle Fuels, 5 Willis Way, Poole BH15 3SS
You'll just need to order some turbine oil, you can get it from Motors and Rotors and other places
Last edit: 5 years 6 months ago by JonTappin.
The following user(s) said Thank You: Wingman1962
Time to create page: 0.258 seconds
