Scratch Built Hannibal
12 Jun 2017 19:48 #13080 by kevinross
Replied by kevinross on topic Scratch Built Hannibal
Hi Brian
I see you have gone for the closed loop design with the turnaround pulley. Very sorry but i can't sit back and see you risk a well built model without offering further advise. I am concerned abut the possibility of failure in this design which has no protection against the closed loop becoming detached from the pulley leading to loss of control.
Full size aircraft make extensive use of closed loop systems but every point is protected against the wires jumping off the pulleys. See the attached pic
When your model buffets around the Cashmoor airways the rear fuselage will be subjected to a multitude of stresses which will cause those control runs to stretch / relax with a strong possibility of whipping off the pulleys. I would recommend that you increase the pulley groove depth (for example - glue additional discs top and bottom ) and /or fix small round pillars / guides close to pulleys provide additional safety retention of the control wires.
12 Jun 2017 21:50 #13081 by Brian
Hi Kevin, I see what you mean about the depth of the pulley grooves. I'll have another look at the set-up with a view to making it a bit safer. Thank you for pointing out a possible failure.
13 Jun 2017 06:23 #13082 by kevinross
Brian
A possible improvement would be to screw three suitable small pulleys similar to these in the attached jpg interlocking (but not touching) as per the positions on the pdf pic.
16 Jun 2017 19:05 #13100 by Brian
Elevator control wires fitted and tested today, full range of movement and no binding, on elevator and rudder. Decided to run the upper elevator wires through the top rear of the fuselage. Lower elevator wires and rudder wires exit through the fuselages sides under the tail plane, the lead outs will be fitted with brass pulleys., similar to those shown. The servos were left running on a servo tester for a half hour or so. No slop in the control surfaces, and all returned to neutral on switch off. Looks quite promising so far.
17 Jun 2017 12:12 #13102 by Brian
Hi Kevin, since you suggested a method of preventing the control wires from jumping off the pulleys, I've been looking at ways of doing it without adding weight. I don't think that the short wire runs from servo arm to pulley are a problem. Its the possibility that something could interfere with the long wire run from control horn to the pulley. Today I made some cheap and cheerful wire guides, I think they'll work alright.
16 Jul 2017 08:04 #13312 by Brian
Decided to have a go at finishing the front of the Hannibal fuselage with sticky backed aluminium foil. Made some expensive mistakes. The stuff doesn't work well on sealed balsa, doesn't work on tissue doped onto balsa either. However, I found that spraying cellulose primer/filler over the tissue, and covering with film did give a reasonable base to work with. The main tool for applying the foil is a sort of thick pencil made from rolled paper, I got mine from Hobbycraft, pack of three different sizes for £1. . There are several videos about cladding on YouTube, most seem to concentrate on large warbirds with fibreglass structures, and lots of panel and rivet detail I found that the foil is tricky to get started without wrinkling. I wasted quite a lot trying different methods. The one that worked for me was to stick a piece of masking tape on the foil itself. Holding the tape allows the backing to be peeled away without touching the adhesive on the foil. Once the foil is positioned, its simply(?) a matter of gently "inviting" the foil to come away from the backing while stroking it down with the paper pencil. The pencil itself needs to have a radius sanded on one end, this helps to get the foil to lay down smoothly. The videos of cladding show the alloy being dry sanded with 320 grit W+D, this might be OK for thicker films, it didn't work with my stuff, and bubbles and wrinkles sanded through. Getting the foil off is something else. A process involving an old artists bristle brush, lots of acetone, and a good deal of "language". It took over an hour to strip the front hatch cover.
16 Jul 2017 08:12 #13313 by Brian
This is the foil being removed from the hatch. A job that should be avoided if at all possible.
16 Jul 2017 15:11 #13324 by 4Pedalsfly
Brian - Very interesting - hard work but well worth the effort.
You mention acetone - where is the best place to buy it locally ?
Thanks
16 Jul 2017 21:00 #13329 by John Bannister
Replied by John Bannister on topic Scratch Built Hannibal
Acetone from Chemist Colin nail polish remover just check the label I used Boots own brand
16 Jul 2017 22:44 #13330 by Brian
Hi Colin, I bought my acetone from Wessex Chemical Factors, they're on the Woolsbridge industrial park, near Ringwood. Their website lists all the stuff they sell. I buy acetone and IPA from them. Worth a look, they sell lots of useful stuff.
Time to create page: 0.459 seconds
