Gromit's Phase 5 Build
30 Sep 2018 20:31 #17880 by Chris001
Replied by Chris001 on topic Gromit's Phase 5 Build
And so onto today's frustration, and I'm still not sure why I found it so hard going, all I was doing was marking out the hinge points, drilling them out and then bevelling the edges, the first two tasks took a little time because I kept feeling the need to make another coffee, but otherwise went well enough.
I'm not sure if it was because the aerofoil changes from none symmetrical at the root to symmetrical at the tip, but I felt like I was stabbing in the dark trying find the right angle. Symmetrical ailerons, centre hinged, with equal up and down travel are far easier.
Oh, and as hard as I tried I just couldn't think of a jig to make that would make a wonderful distraction for a few hours and then magically put the right angle on the bevels!
Anyway they are very close, I just need to double check I have the right amount of travel, and accept I managed to over do the angle on both ailerons so that they can pivot down more then up... yes I am contemplating gluing wood on and redoing them... 1/2 a millimetre would do it :unsure:
30 Sep 2018 21:09 - 30 Sep 2018 21:10 #17882 by MikeSeale
Or sand a little more off to give even more aileron movement. The additional drag from an extra 500 microns clearance won't be noticed.
Last edit: 30 Sep 2018 21:10 by MikeSeale.
01 Oct 2018 07:27 #17883 by Chris001
But you know what they say Mike, A micron here, a micron there, all of a sudden it's more than a couple of thou!
01 Oct 2018 08:14 #17884 by John Bannister
Replied by John Bannister on topic Gromit's Phase 5 Build
500 microns that's 20 thou or one and a half 1/64" or to put it in simple terms 10 hair widths you will be able to drive a coach and horses through the gap. Think of the loss of performance Chris you will never be happy with it.
01 Oct 2018 11:00 #17887 by Phil Ford
joneb wrote: 500 microns that's 20 thou or one and a half 1/64" or to put it in simple terms 10 hair widths you will be able to drive a coach and horses through the gap. Think of the loss of performance Chris you will never be happy with it.
Nice one. :lol:
01 Oct 2018 17:26 #17889 by Chris001
You guys do realise it's not easy being me ;)
01 Oct 2018 18:51 #17895 by DaveBright
Replied by DaveBright on topic Gromit's Phase 5 Build
Chris001 wrote: You guys do realise it's not easy being me ;)
Based on this thread.......it doesn't in anyway look easy being you! :silly:
01 Oct 2018 23:45 #17905 by DavidTappin
Replied by DavidTappin on topic Gromit's Phase 5 Build
A serious suggestion following the plea
Should we be changing Gromit's tag to Peasy?
02 Oct 2018 09:25 #17907 by John Bannister
I don't understand
02 Oct 2018 09:35 #17908 by Chris001
David is trying to call me a lemon ;)
