Gromit's Phase 5 Build
02 Oct 2018 10:01 #17910 by 4Pedalsfly
Replied by 4Pedalsfly on topic Gromit's Phase 5 Build
Chris - This is a quote from some famous engineer.
"PERFECTION IS THE ENEMY OF PROGRESS"
I understand it was first applied to the chap who invented the wheel,
he was not happy until it was balanced & running true within 50 microns.
02 Oct 2018 10:57 #17915 by Brian
Replied by Brian on topic Gromit's Phase 5 Build
I use the 80/20 principle..
80% of what you want to achieve by using 20% of the available resource.
02 Oct 2018 11:38 #17917 by John Bannister
Replied by John Bannister on topic Gromit's Phase 5 Build
David is trying to call me a lemon
Before my time
06 Oct 2018 20:47 #17963 by Chris001
Replied by Chris001 on topic Gromit's Phase 5 Build
The fist job of the day was to make this:
Then it was a bit of a 'bitty' day getting various bits for the fin and rudder dimensioned and marked out. I've cut the ply for servo mounting plates, all lovingly fitted by hand with the utmost finesse and to a tolerance of a merest sliver of a micron ;) The available depth of the pocket of the aileron servo is quite minimal when you take away the 12mm of the servo, the pic shows the depth of the flap pocket which is a little deeper. Still need to add the blocks to screw the servos on, but that can wait till tomorrow.
06 Oct 2018 21:07 #17964 by Chris001
I've not been able to skin the tail as I needed more balsa having trashed several sheets in my mishap with the wing, I used what I had spare to correct my mistake... But that was just a good excuse for not getting on and doing it, as I could get the balsa from just down the road, it's basically not a fun job, it's messy, and seems to always throw a curved ball at me... so I was putting it off.
However they say the end result reflects the initial preparation, so I made sure I had enough space, I can't be the only one that throughout the day collects more and more 'stuff' on the bench and ends up working on the last available bit of the free space.
The Gorilla glue is very sticky and I seem to get it everywhere, so I have several pairs of disposable gloves on hand so I can ditch them rather than spreading the stuff around. I've taken to using a foam roller to spread the stuff out, and I'm sure I get a more consistent film.
But it's done, wrapped up and held down under a box of bathroom tiles, tomorrow I'll see how it's turned out.
Time to create page: 0.331 seconds
