Stearman build
4 years 7 months ago #24041 by kevinross
Domestics have just interrupted work but now progressed the aileron.
L/E is wrapped in 1/64" ply so this was glued to the lower spar, steamed and then rolled in this half tube.
Due to my clumsiness - damage to the T/E needed to be trimmed and capped with 3/32" spruce
The T/E of the aileron fairing also proved weak so this is wrapped in ultra thin carbon tape.
4 years 7 months ago #24042 by kevinross
Ive modified the hinging design with my preferred pin in tube design which are more scale.
4 years 7 months ago #24044 by kevinross
The kit design for aileron operation was this pasolini plate and quick link which had too much backlash and a very short moment arm. Also I am mechanically slaving the upper wing ailerons so a more substantial design was required.
Created this light ply box to hold this heavy duty ball link which is secured by a cross screw. -( and no backlash )
4 years 7 months ago #24070 by kevinross
In all fairness, the first wing (the first raw build ive done for some time ) was a steep skill renewal for me but the second aileron and wing went much quicker so by the time no 4 is complete, it'll be a proper builder. (in my opinion)
4 years 7 months ago - 4 years 7 months ago #24072 by Phil Ford
Starting to resemble something that eventually will fly. B) Nice work Kevin. By the time you have got to wing 4 you'll be thinking "Why did I not do it this way earlier!" Myself I have said this many times with multiple items that had to be made up identical. :lol:
Last edit: 4 years 7 months ago by Phil Ford.
4 years 7 months ago #24136 by kevinross
For the first wing L/E sheeting i just formed it around the bathroom towel rail but had some difficulty fixing. Subsequently shaped them on a tighter radius allowing them to fit like a glove dry. Now they can be fixed without pins.
Definitely getting the hang of this old building lark !
Time to create page: 0.455 seconds
