Morris Dancer build
22 Jan 2025 16:06 #26913 by Phil Ford
Yeh! You would say that....:angry:
22 Jan 2025 16:19 - 22 Jan 2025 16:24 #26914 by Phil Ford
The day before I filled in the spar webs and I glued the sheeting to the bottom spar. The sheeting overlaps by 10mm.  The sheeting front edge was weighed down overnight using a spirit level. This would give it a starting bend (hopefully).  Today I glued the leading edge and used large hard balsa ailerons to keep an even pressure under the clamps.  A few coffees later I then glued the more sheeting over the centre and servo bays.  That's that for now till tomorrow for the wing.
Back to the fuselage, the landing gear ply is now glued in place.  An extra former was also made and glued to guide the servo control wires through the fuselage. Will trim as necessary once the tail is fitted.
Also glued an ESC mounting to the landing gear ply. This will raise the ESC capacitors clear of the landing gear wire and enables to easily fit cable ties to secure the ESC.
Last edit: 22 Jan 2025 16:24 by Phil Ford. Reason: Miss a bit
24 Jan 2025 16:35 - 24 Jan 2025 16:37 #26915 by Phil Ford
This morning I was horrified to find that some of the sheeting on the leading edge had expanded up at the centre join.  After pondering how to solve this problem and bearing in mind I am virtually out of 1/16th balsa sheet, so just enough for one go at it.
I will cut back to the first full rib, back to the centre of the top spar and partly on to the leading edge. I discovered that the balsa had not stuck to the 1/2 rib and the first rib.  That maybe was the problem.  The half ribs I think is crucial as it is the one that takes the load when pushing the wing into position.
Repair done. A little bit of filler required.  The wing now sits quite well in the fuselage. Solar Cover ordered and should arrive Tuesday so I get on with covering all the parts and fitting.
Last edit: 24 Jan 2025 16:37 by Phil Ford.
24 Jan 2025 17:44 - 24 Jan 2025 17:45 #26916 by kevinross
you could consider a thin bandage of glass cloth to reinforce the L/E sheeting joint. I covered mine anyway to provide a bit more resilience to the rubber bands
If you want some and going to Cashmoor  Sat let me know
Last edit: 24 Jan 2025 17:45 by kevinross.
27 Jan 2025 10:11 - 27 Jan 2025 10:23 #26917 by Phil Ford
Thanks Kevin but saw your post to late. Job done now anyway.  Fuselage underside completed - grain running crossways - more strength that way especially when picking up the model and holding it too tight.  I have made a hatch where the ESC cables enter the fuselage. Most of my stock of ESC's have relatively short power leads and the extension plug would be internal and difficult to access if the ESC fails or needs replacing for a bigger one. Should not think so as the one I have chosen from my stock is a ZDW Mantis 85 amp overkill.:sad: as the bullets are 3.5mm so matches the motor leads.  Me being too lazy to resolder leads.  The Ripmax motor Quantum 25 is 3541 1070 Kv. 3 to 4 cells. The X mount aligns perfectly with the pre-drilled holes in the firewall
Last edit: 27 Jan 2025 10:23 by Phil Ford.
28 Jan 2025 11:26 - 28 Jan 2025 11:27 #26918 by Phil Ford
Today, I thought I would get on with the landing gear as the wing covering won't be here today.  Saddles fitted but came to a standstill as the copper wire that secures the legs together will not solder. I have tried to two types with two fluxes but to no avail. I think I will have to visit a local man to weld 'em.
Rudder servo fitted. The Macgregor servo slides in neatly with no hacking of around 1.5mm of the mounts in the wing. I used the servo screws without anti-vibration rubbers. Screws are going through 1/4 balsa. Screwed in then back out, a drop of thin CA in the holes and back in again.
Last edit: 28 Jan 2025 11:27 by Phil Ford.
29 Jan 2025 16:13 #26919 by Phil Ford
While some glueing of the wing tips to cure I thought what else can I fiddle with.  I fitted the ESC, paired up a spare receiver, created a model on my X20R. Plugged in a 3 cell lipo and found an APCe prop 11x5.5.  Full throttle shows 32.5 amps so just over 406 watts. Theoretically prop is turning at 12,500 RPM
Oh!  Knock on door. The wing covering has been delivered
30 Jan 2025 07:24 #26920 by C.Morris
Phil,
I think you're going to be a little disappointed with that motor. I've just looked at what I use and it's about 900w.
www.rapidrcmodels.com/dys-d35484-1100kv-...er-motor-15178-p.asp
30 Jan 2025 16:21 #26922 by Phil Ford
Um!  From a quick weigh of the components I estimate 1.5kgs  which is roughly 3lbs. So, in my case that's comes out 130 watts per lb.  Not looking for ultimate performance but on the other hand want some pulling power.  My old Weston Hype 60 was 1200 watts on 6 cells.
I will have another look in my motor stock and see what I can find.  If not them maybe your suggestion.
30 Jan 2025 16:25 - 31 Jan 2025 09:01 #26923 by Phil Ford
As it was dry day I took the chance to get outside in the drive and sand down the wing tips and other high spots.  I nearly gave up as the temps was 4C and I could not feel my fingers on the sanding block. Got it done and got back in to the conservatory.  Heater on, wrap hands around a coffee. Can now get the wing covered. Transparent blue and leading edge Oracover mid blue.  Servos installed.
Last edit: 31 Jan 2025 09:01 by Phil Ford. Reason: grammar
Time to create page: 0.402 seconds
