Morris Dancer build
27 Dec 2024 23:46 #26899 by kevinross
The instructions say to start the L/E sheeting 10mm aft the wing spar so I marked this with pins
For the main adhesion i used aliphatic but i used 10mm Cyno aft the spar
This method allowed me to accurately position the sheet and fix in a few seconds, then pull and roll the sheet around the ribs
the last sheet retained its shape for over 6 hrs after steaming
Due to the fragility of the wing ribs i decided to retain the lighting plugs until the top L/E sheets were glued
28 Dec 2024 21:11 #26900 by kevinross
nearly finished - good job as I'm on my last dregs of glue
28 Dec 2024 21:25 - 28 Dec 2024 21:32 #26901 by kevinross
 A further reminder that the wing ribs are quite vulnerable before you fix  the 1/4" wide capping. (especially if your a bit clumsy like me )
Even with the 1/2" wide capping on the tip ribs i felt they would slightly vulnerable so i fitted som 3/32' full tips
While i'm sure the servo ribs capping would have provided plenty of support for the aileron servos I just found it easier to use the left over 1/16" cross grain to fully box these ribs. - this would make feeding the servo wire awkward so i rolled some thin paper around a 1/2" rod and applied a few blobs of cyno to create the wire guides
Finally - I know Chris has proven his design but i was concerned how well the 3/16" sq T/E section would retain the CA hinges long term so i supplemented this with some of the 1/4" scrap - this is best applied with only one T/E capping fitted so you can plane / sand to the t
T/E taper
Last edit: 28 Dec 2024 21:32 by kevinross.
28 Dec 2024 21:39 - 28 Dec 2024 21:41 #26902 by kevinross
going back to the start - I used the triangles to set the angles of Fin and rudder but didn't glue. This made plunging the hinge slotting tool much easier
Last edit: 28 Dec 2024 21:41 by kevinross.
05 Jan 2025 20:38 #26903 by kevinross
I thought it best to do a dry run for the controls. Not totally sure how Chris intended to run pull pull elevator controls but I inserted a small nylon tube thru the Fin / rudder fairing and couldn't avoid fouling the rudder.
So added some more 1/4 balsa to the rudder internally to allow a small trim of the lower surface
07 Jan 2025 17:30 - 07 Jan 2025 17:31 #26904 by C.Morris
Like this...
There is a laser cut hole in the tail centre section.
Last edit: 07 Jan 2025 17:31 by C.Morris.
The following user(s) said Thank You: kevinross, Phil Ford
11 Jan 2025 10:58 #26905 by Phil Ford
Take note of the slight error I made. The battery tray is notched to go just one way into the fuselage sides. Therefore make sure you glue the bracing tabs on the correct side.:unsure:  As I found out!
13 Jan 2025 16:58 #26906 by Phil Ford
I started with the tail surfaces first. Dry fit, then glue n pin.  Used lipos to keep flat whilst gluing the ply to the balsa (the balsa is on the outsides Kevin 8)
13 Jan 2025 17:03 - 13 Jan 2025 17:08 #26907 by Phil Ford
With the fuselage sides sorted I then inserted the battery tray after a few dry fits. I found
I had to apply a little chamfers on the tray tags to get the tray to slide into the fuselage sides.  Once happy with the fit I fitted the F1 using epoxy and the lower bracing ply and the initial forward landing bear plate with Aliphatic.   I will leave this area open for now so I can easily access the firewall if I decide to fit 3mm spike nuts to secure the motor.  After a night of setting I then glued the tail skid plate. The fuselage is starting take shape.
Last edit: 13 Jan 2025 17:08 by Phil Ford.
13 Jan 2025 18:21 #26908 by kevinross
After considering various covering solutions, have ordered solarfilm direct. (they still have considerable stock)
Works out cheaper due to less waste because one width of 67cm covers a single wing span
Time to create page: 0.381 seconds
