Mk 11C Hurricane winter build
10 years 6 months ago #4056 by kevinross
Replied by kevinross on topic Mk 11C Hurricane winter build
MikeSeale wrote: Because I'm not an engineer and also do not have petrol engines...I'll stick my neck out and ask "what's lapping?" That'll save embarrassment for anyone who does own a petrol engine but was too shy to ask.
As your not and engineer and don't operate petrol engines, just think of lapp dancers and sleep well tonight
but seriously - here is one of the links i was referring to
www.grosbeakrc.ca/hangar/pulse125/modifications/lapping.html
10 years 6 months ago #4064 by
Replied by on topic Mk 11C Hurricane winter build
Lapping, mechanics and fitters do the lapping, engineers inspect the result ;)
10 years 6 months ago #4071 by Dante
Replied by Dante on topic Mk 11C Hurricane winter build
Referring to Kevin's lapping info and the informative URL it so happens that the April issue of RCM&E has an article by Brian Winch the engine guru from OZ that refers to lapping of carburettor reeds especially glass fibre ones that seem to be the case in the URL piece. The need arises apparently from the reeds being punched out and thereby having a microscopic burr which causes poor start and running in some cases (pages 89&101). In such a case Brian advises using at least 1200 with a preference for 5000 wet and dry abrasive paper and carefully lapping the reeds on a glass surface for flatness. That is not detracting from the URL article however one would expect that gaskets should effect the necessary seals in the case of the casing as discribed in the URL piece whereas the reeds are the actual metering device of the gas/oil/air mix directly into the manifold.
An article well worth a close read for all petrol heads. :whistle:
10 years 6 months ago - 10 years 6 months ago #4075 by JRI
Replied by JRI on topic Mk 11C Hurricane winter build
Photos
Last edit: 10 years 6 months ago by JRI.
10 years 6 months ago #4128 by DaveBright
Replied by DaveBright on topic Mk 11C Hurricane winter build
Where's progress at Pete?
  • Banned
  • Banned
10 years 6 months ago #4131 by flyingpete
Replied by flyingpete on topic Mk 11C Hurricane winter build
Progress is Dave,underside of wing now has invasion stripes added to aid orientation as Jon recommended, new radiator fitted and painted sourcing the retracts so will be back in action very soon, can't wait for a nice sunny afternoon up cashmoor so I can do some low level straffing runs :woohoo:
