Provost
  • Banned
  • Banned
10 years 3 months ago #4556 by flyingpete
Made a start on the aileron to show scale hinging. The drawings show brass tube bearing with piano wire hinge pin.I've used this method before and vowed to never use it again as they went very sloppy guickly.
So any of you engineers have a better solution please let me know.
10 years 3 months ago #4557 by Phil Ford
Replied by Phil Ford on topic Provost
Depending on rod diameter, would Sullivan outer snake casing be any good as a bushing. Just a thought. :huh:
10 years 3 months ago - 10 years 3 months ago #4558 by kevinross
Replied by kevinross on topic Provost
As you may know Glens models hinges are similar. They use large diameter brass tube - It doesn't get sloppy but it migrates.
I think plastic bushes & piano wire is the way to go. An equivalent to the old micro mold snakes made for bowden cable inners would make a good bearing material.
My Decathlon (which i will have at Cashmoor tomorrow) uses 3mm carbon rod on ply hinges.
Last edit: 10 years 3 months ago by kevinross.
  • Banned
  • Banned
10 years 3 months ago #4559 by flyingpete
Flaps are similar construction but this time they are hinged on the bottom, thanks for the suggestion Phil and.Kevin,anybody got some snake.off cuts?
  • Banned
  • Banned
10 years 3 months ago #4560 by flyingpete
Forgot to say I'm going to use 3mm carbon rod for the hinge pin so the snake outer will have to fit that
10 years 3 months ago #4561 by
Replied by on topic Provost
What about very small shielded ballraces - the type fitted into some of the small brushless motors could work.
Ron
Time to create page: 0.302 seconds
