DH VAMPIRE
17 Sep 2015 16:24 #6038 by flyingpete
Glassed the underside of the vampire leave to cure overnight, do the same on the panther
18 Sep 2015 07:36 #6046 by flyingpete
OK then chaps! It's 07.25 and I'm in the garage already, must be mad.Anyway the resin has dried and time to trim the cloth.The only and best way to do this is,using a medium sanding block gently sand the edge using downward strokes until the cloth falls away leaving a crisp faired edge.Once done it will have a sand with 400 grit paper and a second coat of resin.
18 Sep 2015 08:10 - 18 Sep 2015 08:12 #6049 by JRI
Replied by JRI on topic DH VAMPIRE
Pete, how much extra weight does glassing add to a model? And how much extra structural strength do you gain?
I.e. do you build the model lighter and with thinner balsa if you know you are going to glass it?
Last edit: 18 Sep 2015 08:12 by JRI.
18 Sep 2015 10:07 #6051 by flyingpete
Good question John! As with many things it's a compromise, what size model and the type and what you hope to achieve. There is no getting away from it a glassed finish is heavier than say profilm or solartex.The system I am using is 49 gramme cloth and 2 coats of resin which will give a ding proof finish and will add a bit of strength but not much heavier, and a glass like finish with little extra weight. On the other hand if you want a bullet proof finish you can use 150 gramme cloth and 4/6 coats of resin which will turn a wooden airframe into a glass fibre model but the weight gain would be horrendous. To answer your other question I would never skimp on balsa thickness and rely on the glass to make up the strength.
My preferred finish is to cover a model in solartex and painted but as with scale jets they have more scale detailing than most and a glass finish is an excellent base to set out the detailing.
Pete
18 Sep 2015 19:55 #6055 by flyingpete
Had a good day on the vampire and panther, trimmed the cloth on the underside, sand and second coat of resin. Sealed top of wings,glassed underside of outer wing panels and canopy on both models.
Hopefully glassing will be done early next week and a coat of primer and then the fun starts with hours and hours of cutting back with wet and dry 400 grit paper.The purpose of the first coat of primer is a guide to highlight high and low spots on the air frame.The idea is to remove the primer coat with wet and dry which will remove all the high spots and any primer left after rubbing down will highlight low spots.Two options to fill the low spots,first is a very very fine automotive stopper filler or my preferred method is a coat of good quality high build filler primer.
Pete
20 Sep 2015 13:33 #6073 by flyingpete
It's always sods law! 1sq foot of glass cloth short to finish glassing the vampire so had to order more which hopefully will be here tomorrow /Tuesday. started rubbing down the top hatch and a coat of primer
21 Sep 2015 10:49 - 21 Sep 2015 10:49 #6086 by flyingpete
Outer wing panels cut back and a coat of primer, now it has started raining , no more spraying for the moment :(
Last edit: 21 Sep 2015 10:49 by flyingpete.
22 Sep 2015 19:42 #6134 by flyingpete
After a bad start this morning due to dropping a pot of resin on the floor and splashing up on my jeans and trainers and then cutting through the Rudder lead on the boom,I salvaged the day.
Cut back the main airframe and wings with wet and dry ready for a base coat tomorrow. I need to do some surgery on the boom to put in a new servo lead re glass the area.
I have given the inside of the fuselage a coat of resin and this will then be sprayed grey. Hopefully will upload some pics tomorrow if the weather stays kind.
Pete
23 Sep 2015 12:25 #6158 by flyingpete
Airframe and wings in primer coat
23 Sep 2015 15:17 #6163 by Phil Ford
Looking good Pete. I love that stealth colour, so suitable for our frequent weather and skies. :lol:
Time to create page: 0.713 seconds
