Angel dust
10 years 1 month ago - 10 years 1 month ago #5321 by flyingpete
Replied by flyingpete on topic Angel dust
Mike,your workshop is far too tidy :ohmy:
Last edit: 10 years 1 month ago by flyingpete. Reason: text
10 years 1 month ago #5323 by MikeSeale
Replied by MikeSeale on topic Angel dust
flyingpete wrote: Mike,your workshop is far too tidy :ohmy:
15 minutes before that photo was taken it was not so tidy. And here's a pic looking the other way today.
As for the build...not a lot to show but I cut templates and then a foam wing. Tomorrow it's mounting the retracts and servos into the wing, and suitable tunnels for their servo leads before skinning.
10 years 1 month ago #5327 by Phil Ford
Replied by Phil Ford on topic Angel dust
I was going to mention that too Pete! And space under the worktop, WOW! ;)
10 years 1 month ago #5339 by MikeSeale
Four skins...
...two left and two right, ready for sanding
10 years 1 month ago #5340 by MikeSeale
Most of the work today was on the foam cores. Cutouts were made for the retracts and aileron servos. After cutting the sides with a sharp scalpel I used a sanding drum on my dremel to cut into the foam. Dremel in one hand and the workshop vac in the other...saves a lot of mess.
The mounting plate for the retracts has 4 dowels epoxied into the foam. These are angled like a saw-horse and will hopefully spread the load on those heavy landings.
I also cut channels for the servo leads. I decided to make them big enough to take the large connector on the end of an extension lead so I can easily swap servos and retracts if necessary.
Tomorrow it's wing skinning time and fin construction...
10 years 1 month ago #5351 by MikeSeale
First job of the day was to lightly sand the wing skins...much easier to sand before you glue them to a curved wing. Then it was time to glue the skins on using Gorilla glue. This is when I spread the glue onto the freshly sanded surface instead of the unsanded side :oops: After spreading the glue the skins are added and the wings are placed back in their offcuts, then taped and weighted down for a few hours while the polyurethane glue foams and dries. Compared to contact adhesive or epoxy, this is a much cleaner and easier glue to work with.
The base of the fin was tack glued in place and rough carved. The fin itself is drying.
The wheel wells are lined and leading and trailing edges are added.
Time to create page: 0.891 seconds
