Royal Kit for Bleriot Mk XI
  • Phil-C
02 Sep 2015 18:25 - 02 Sep 2015 18:29 #5737 by Phil-C
Replied by Phil-C on topic Royal Kit for Bleriot Mk XI
The target. Same kit. This model was sold on after a few flights,
There is a U Tube video of it in flight, at
Last edit: 02 Sep 2015 18:29 by Phil-C.
02 Sep 2015 20:07 #5758 by flyingpete
Replied by flyingpete on topic Royal Kit for Bleriot Mk XI
Must be nearly finished by now Phil? :P
  • Phil-C
04 Sep 2015 09:38 #5774 by Phil-C
Been doing other stuff, ground maintenance, flying, young pilot training......
04 Sep 2015 21:48 #5802 by 4Pedalsfly
Replied by 4Pedalsfly on topic Royal Kit for Bleriot Mk XI
Phil-C wrote: Been doing other stuff, ground maintenance, flying, young pilot training......
Phil - Great hand launching technique , she's welcome to launch my gliders at Cashmoor.
No name's mentioned but can only be an improvement over some launches - nose high , tip stall but enough power
to get away with it.
Colin. A
  • Phil-C
05 Sep 2015 09:43 #5810 by Phil-C
Obviously, I didn't post the numerous other shots.....
  • Phil-C
14 Sep 2015 09:40 - 14 Sep 2015 09:43 #5976 by Phil-C
Starboard wing, nearly ready to cover. I decided to leave it as designed, so no extra spars, Mike.
I will complete the location tubes with laminating epoxy after the wings have been offered up to the fuselage.
You can just make out the built in washout at the tip.
Last edit: 14 Sep 2015 09:43 by Phil-C.
  • Phil-C
14 Sep 2015 19:32 - 14 Sep 2015 19:34 #5996 by Phil-C
After another 5 or 6 hours bashing and I nearly have both wings.
Been doin' some weighing, so tomorrow I will post expected weight etc. and seek advice on power plant.
Last edit: 14 Sep 2015 19:34 by Phil-C.
  • Phil-C
16 Sep 2015 11:19 - 16 Sep 2015 11:19 #6025 by Phil-C
The set up used in the videoed model above was an E-Flite E46 on 4S
I see Turnigy do a G46 which is similar, on the face of it.
The airframe will weigh 1553 gm or say 3-1/2 lb. That's including all completed parts, all wood and wire for the fus, the 5" spoked wheels, a bag of nylon two coats of dope and two JR591 servos.
The motor weighs 303 gm (0.67 lb), a Turnigy Nanotech 4s 2200 battery 239 gm (0.53 lb), a 60 A ESC say 1/2 lb
Add 1/2 lb for wires etc. Grand total weight should be 5.7 lb plus prop and driver.
Model is 51-1/2 in w/s and has a wing area of 564 in sq
Motor spec is here.
www.hobbyking.co.uk/hobbyking/store/__36...w_UK_Warehouse_.html
Am I on the right lines?
Last edit: 16 Sep 2015 11:19 by Phil-C.
16 Sep 2015 12:30 #6028 by MikeSeale
Replied by MikeSeale on topic Royal Kit for Bleriot Mk XI
Firstly, if this model were built for 'glow' you might use a 40/46 but would be stooging around at part throttle for most or all of the flight. as such, the E46/G46 motor is going to be way too powerful for this model. The lighter G32 would probably give ample power, however...
...secondly, the model has a short nose and might benefit from a heavier motor, so the E46/G46 might be spot on.
Finally, if the model does balance tail heavy, you could use a bigger battery, say 3000mAh, instead of the 2200mAh...better to have a longer flight than carrying around lead.
16 Sep 2015 21:56 #6035 by 4Pedalsfly
Phil - Been doing a few basic sums based on your data, Mike just got in ahead of me.
I'm in general agreement with Mike & here's my bit.
The E46 & G46 have identical specs & are rated at 40 A continuous, based on 4 cell LiPo this will give around 640 Watts.
With the model weighing say 6 ibs you have on tap 100 Watts / pound ie plenty in hand.
The wing area & weight given equates to a wing loading of 24 ozs per sq foot so the extra power may be a benefit.
Flying around on half throttle ( 20 A ) you will probably get around 8 mins on the 2,200, if you need extra weight in the
nose then a bigger battery is the answer. I have some 4 cell 3,300 LiPo's which we could do some balance & power / prop tests with.
Trust this helps.
Time to create page: 0.417 seconds
