9 years 6 months ago - 9 years 6 months ago #8183 by
There is not much more I can say other than... Wow.
Blimey, just to come up with the idea and then to work out how all the timings and interactions are going to work is just wonderful. Thanks for finding it and posting David, I remember being mesmerised by my dad's ball bearing clock when I was a kid, this is on a whole new level.
Last edit: 9 years 6 months ago by .
9 years 5 months ago - 9 years 5 months ago #8302 by
There's not been anything new on this thread for a while, so I thought I'd see any anyone can see any flaws in my thinking with regards the correct axle positioning of the main wheels
I'd originally established my ground level and mocked up the retract on the plan to get my measurements:
But this morning it occurred to me that the wing has dihedral and is tapered from root to tip, so any measurement at the root of the wing as I have been doing on the plan is inaccurate.
When Mike kindly sorted out the foam cores for the wings, he built in both the wing taper and the dihedral, so I've measured the bottom half of the foam core waste at the retract position and at the root.
The difference being 11mm (94mm & 105mm) and plan to add that to my original measurement I took at the root down to my ground level (minus half the wheel diameter)
Does this all sound about right?
Last edit: 9 years 5 months ago by .
9 years 5 months ago #8303 by MikeSeale
That all sounds fine...the bottom of the wing does have a lot of dihedral in order to accommodate the 8mm on the top. However, I did not take this into account and ended up ok.
9 years 5 months ago #8304 by
You wanted a positive angle of attach anyway, you might have just got a little more than you planed for. Does the Blue Angel have 0º angle of attack or negative, I'm assuming it was the sticking to the ground nature of the Blue Angel that made you purposely build in a positive angle of attack for the Atlas. All the similar MK plans seem to indicate the undercarriage is set to give 0º wing incidence to ground level.
9 years 5 months ago #8305 by MikeSeale
TBH, the Atlas appears to sit a little more nose down than the Blue Angel. I don't have incidence meters so cannot tell you how they sit in degrees. The nose-down attitude of the Atlas is possible an advantage for landing...it tends to bounce less...but both are very similar and it's early days yet.
9 years 5 months ago - 9 years 5 months ago #8307 by Phil Ford
With reference to the Curare and other trike gear generally, Jon told me that the comp boys used to have nose down attitude to help stick it down and avoid bounces on landing.
Last edit: 9 years 5 months ago by Phil Ford. Reason: Added On Landing
Time to create page: 0.638 seconds
