27 Apr 2016 19:35 #8699 by Chris001
It's covered, thank goodness... a bit dodgy in places... but it's done, just some decals to go on, then I can start setting it up with all the electronics.
27 Apr 2016 20:13 #8701 by Chris73
Very impressive Chris, look forward to seeing it fly
27 Apr 2016 21:04 #8703 by Phil Ford
Lovely job. You should be pleased with the project Chris. Fitting out with the hardware, the easy job. ;)
27 Apr 2016 22:47 #8704 by 4Pedalsfly
Replied by 4Pedalsfly on topic Winter build project: Wolfgang Matt’s ATLAS
Chris , well done looks good.
You will enjoy this story titled " The Bandage Covering Method " - quite a few years ago a guy was keen to take up the hobby & built a model from a kit. All went well till the covering stage
when he had great difficulty with the heat shrink film, his solution, cut it into strips & apply
mummy fashion. I maidened the model which flew really well .
Colin. A
27 Apr 2016 23:45 #8705 by MikeSeale
Certainly looking good...and it will soon be time to test out those retracts! I bet you can't wait to be in the air again after all these weeks?
28 Apr 2016 07:38 #8706 by DavidTappin
Replied by DavidTappin on topic Winter build project: Wolfgang Matt’s ATLAS
Well done Chris (at last), that looks absolutely splendid!.
When I see it fly It will be good to imagine my snakes up in the air at last after languishing for years in my stock of accessories.
28 Apr 2016 07:57 #8707 by Chris001
Has it only been weeks I've been without a plane, it feels like months! I think it will be good to get back flying again, and testing those retracts out, I'll bring some spares to the field just in case :unsure:
Colin, that sounds like a very sensible solution to the nightmare of covering.
David, your snakes are in pride of place running down the centre of the fuselage.
I really am very grateful for generosity of the members here, the help and advice I've received, and the bits of piece I've been given and lent to help me build this plane has been wonderful. Thank you.
Lets just hope all things now fall into place, and go together as intended, and I'll be able to get it into the air soon.
28 Apr 2016 15:58 - 28 Apr 2016 15:58 #8708 by JRI
4Pedalsfly wrote: Chris , well done looks good.
Colin. A
That was 'me' Colin. And the model still exists in same 'bandage' covering under the current ownership of Big Dave. :)
Last edit: 28 Apr 2016 15:58 by JRI.
28 Apr 2016 18:25 #8710 by 4Pedalsfly
Colin. A
John - I was very carefull not to give clue to "Bandage" man's identity, good of you
to put your hand up, amazed Citaborea is still flying, is the Irvine 40 still pulling it round ?
Colin. A
29 Apr 2016 20:55 #8719 by Chris001
The hinges are glued, hopefully they will still move in the morning when the epoxy has had time to totally harden.
Looking ahead I plan to set up the servos and control linkages tomorrow. I cannot find any control throw details for the Atlas, so I thought I'd take a look at the recommended setup for the Curare as that's got to be in the same ball park area.
www.der-schweighofer.at/public/files/original/6656/66569.pdf
Alas it's all German to me :(
In the aileron column are the two different measurements for up and down, is this differential?
And it seems there is a heck of a lot more down elevator than up elevator (H = High and T = Low)
Anyway, how does this sound for the initial set up of that Atlas:
Ailerons:
High rates: 15º up and down
Low rates: 12º up and down
Elevator:
High rates: 16º up and down
Rudder: as much as I can set without fouling anything.
Time to create page: 0.387 seconds
