11 Apr 2016 19:54 #8593 by JonTappin
The measurements you have done will be fine Chris, no need to measure to the nose.
11 Apr 2016 21:49 #8595 by MikeSeale
This is one of the more tricky jobs to sort out. The reason it was tricky is that after measuring and checking several times, you have to (somehow) secure the wing to the fuselage, drill for the wing bolts and get the bolt-plate lined up. I can't remember how I did it except I know it took a lot longer to achieve than expected.
It's all taking shape nicely, Chris. Once you've got that belly fairing made you'll be so close to covering...
I used a wobbly ruler because I didn't have any American aluminum to hand.
11 Apr 2016 23:31 #8597 by Chris001
Thanks John, it's looking okay, I must have measured each measurement at least half a dozen times once I was sure I was lined up, I'll probably measure it all again tomorrow too.
Hi Mike, sorting out the wing bolts will be tomorrow evening's job! Good to know it's a nice easy and straightforward job :unsure:
12 Apr 2016 07:18 #8598 by Chris001
Sorry Jon, I spelt your name wrong, hopefully the first and last time.
12 Apr 2016 21:17 #8601 by Chris001
You were right Mike, it was one of the more tricky jobs :unsure:
I've still got to epoxy the cross piece in, but so far it's looking okay and fits together without any wrangling!
Better M6 bolts on the way, luckily I had the captive nuts in stock.
12 Apr 2016 23:30 #8602 by MikeSeale
Looking good, and so close to finishing now. Once that wing fairing is done you'll have to think about covering
13 Apr 2016 07:28 #8603 by Chris001
I'm hoping that I'll have started the covering at the weekend. I'm in Wales today so no chance of getting anything done tonight, but if I can get the wing fairing done and the tail plane lined up and glued in two evenings I'll be happy, but probably optimistic.
18 Apr 2016 17:24 #8633 by Chris001
Yep, I was woefully optimistic, maybe I'll be starting to cover next weekend!
Anyway I've just done a little gluing up job before I start to make tea.
Slowly getting there.
19 Apr 2016 09:21 #8636 by Phil Ford
Seem to be really rolling along now Chris. Once you got the wing set up and aligned you can also set your tail plane position. I am looking forward to seeing the finished article. ;)
21 Apr 2016 17:11 #8638 by Chris001
Still some work to do with a little filler here and there, and then a good sand, oh, and bevel the control surfaces, but having got the nose retract in, I really wanted to see what it looked like with the wing on.
Time to create page: 0.441 seconds
