9 years 10 months ago #6866 by flyingpete
Blimey! Is someone actually going to start building one of these badboy's :woohoo:
9 years 10 months ago - 9 years 10 months ago #6867 by
Blimey Pete, give us a chance, my wood order went in last night, if Mike ever tells you it'll only cost £50 then add at least half again :woohoo:
Anyway, I had hoped the wood would arrive before the weekend, it looking a tad wet and windy, but alas it'll won't be shipped until Monday.
In the mean time I've been deciding how best to test the wood so that I can be confident that it meets my demanding requirements. For example we all know resonance can be very dangerous as it can shake a plane apart, so I've decided to measure the natural resonance of all the wood and ensure that I don't put harmonically similar wood next to each other, for example this piece of wood resonates to the note A when wacked:
The other thing I need to consider is the impact resistance of the wood, the size of hammer and velocity which it was swung were all scientifically calculated to simulate one of my landings. :whistle:
Please note the above image is for Simon, who berated me at the weekend for a lack of balsa bashing :evil:
Please also note, no balsa was harmed the creation of these photos.
Last edit: 9 years 10 months ago by .
9 years 10 months ago #6868 by AlanF
That's dedicated work Chris. Are you going to fit a truss rod to adjust the wing incidence?
9 years 10 months ago #6869 by DaveBright
Chris....all this about notes and harmonic resonance? Does that mean that (God forbid it ever went in) would the sound be less or more pleasant?
9 years 10 months ago #6870 by
Mr Bright, how could you even contemplate such a thing, I'm shocked ;)
However I suspect it might sound a bit like this... imagine an electric guitar with a lot of distortion, now scrape the edge of the pick down the bass e string towards the nut before strumming a big fat E minor chord, and if you happen to be playing Alan's Strat, give the whammy bar a good slow wobble at the end. :pinch:
Alan, I'm contemplate the biflex tussrod and micro tilt adjustment ;)
On a serious note, when joining the extra lenght onto the fuselage side, I'm assuming the join is reinforced with the ply doubler, but is it also wise to do a scarf joint?
9 years 10 months ago #6871 by MikeSeale
It won't hurt to do a scarf joint, but the Blue Angel plan just has a butt joint and the ply holds it together. I'll do the same on the Atlas.
