WMAC Group build - Impressivo
21 Dec 2013 12:12 #879 by kevinross
I have photos of all the main stages plus written some ENGLISH statements against all the main stages because i think some group build members have NEVER built a kit and may find the whole process a bit daunting.
21 Dec 2013 12:59 #882 by Phil Ford
Excellent Kevin! :woohoo:
Yes, an article on the build will be useful for reference or for new builders wanting to try their hand at kits in the future.
21 Dec 2013 15:39 - 21 Dec 2013 15:44 #883 by kevinross
Servo installation
Dry run carried out using my servos (size 11.5 x 23.5) which looks like the max size without protruding the airfoil surface.
see attached pics
Last edit: 21 Dec 2013 15:44 by kevinross.
21 Dec 2013 16:58 - 21 Dec 2013 16:59 #885 by JonTappin
Message for Chris H, Mike was kind enough to drop my kit round today, he also dropped yours here as you are not far away :)
Last edit: 21 Dec 2013 16:59 by JonTappin.
21 Dec 2013 18:01 #887 by DavidTappin
Jon said to Chris
Did he leave mine too? I thought that was the arrangement, otherwise I'll make a trip to Verwood tomorrow to collect it, I can't wait 'till after Boxing Day to get started, I'm getting left behind!
David
21 Dec 2013 18:06 #888 by JonTappin
You obviously haven't read my text :)
Of course I have yours to, how could I forget you! I only posted about Chris as I don't have his number.
21 Dec 2013 18:11 #889 by Chris73
Thanks John, can you please PM me your address and maybe I could collect Monday on the way home from work??
21 Dec 2013 19:53 #890 by JonTappin
Sent
22 Dec 2013 14:44 #892 by kevinross
Just completed both wing structures so have the following recommendation -
Its essential to widen / ease all the gaps in the L/E to allow the ribs to slide fully home using a narrow 1.5mm wide warding file (failing that, double up a couple of the wife's emery boards - unless you have your own !!)
If you don't, the leading edge will move forward and drag the rest of the wing ribs inboard with it. In retrospect i should have eased these gaps a bit more aggressively as this would made the construction easier. (at least iv'e repeated this minor discrepancy on both panels !! )
  • Stuartmck
22 Dec 2013 20:15 #894 by Stuartmck
i also received mine yesterday - thanks Mike. Doubt if I will start before Thursday.
