WMAC Group build - Impressivo
11 years 5 months ago #1178 by
Looks quite handy!
Stuart
11 years 5 months ago #1179 by
David, couldn't quite hear you. :dry:
Is there not one of those launching devices hanging up in the hut? :sick:
My weight is now 410 gram for the complete airframe and 380 gram for the hardware, 790 gram in total. :unsure:
11 years 5 months ago #1180 by DavidTappin
Phil, unless your airframe weight includes the two servos its a bit porky. Mine is 380 grams including the servos.
But the rest of my hardware is heavier than yours, what battery are you using? Mine is only a 30C 2100 3S-1P Kokam but it weighs 210 gram.
Perhaps, just like me, it put on weight over Christmas.
11 years 5 months ago - 11 years 5 months ago #1181 by
410 includes servos, ailerons, fins horns. H/W is 2200 LiPo, motor, controller, prop collett, reciever, all plugs and sockets soldered. Bat weighs 185 gram. Overlander 30 C.
Last edit: 11 years 5 months ago by .
11 years 5 months ago #1182 by Dante
Replied by Dante on topic WMAC Group build - Impressivo
All this talk of fat batteries, feed them less calories, try Kellogg's Special K. :whistle:
11 years 5 months ago #1183 by 4Pedalsfly
Replied by 4Pedalsfly on topic WMAC Group build - Impressivo
Mike - I've used the masking tape method on a number of models with no problems.
The servo usually goes either into a balsa box or cut out in a foam cored wing, the servo
is a tight fit and once the glue sets it will not move.
I used this method on a 2.7 m scale glider for fixing the flap & aileron servos into a foam cored wing
and four years later they are still firmly attached.
Colin.A
Time to create page: 0.314 seconds
